AVS › AVS Forum › Audio › Speakers › Does the material of the woofer make a big difference??
post #1 of 6
Hey guys
Does the material of a woofer on a floor standing speaker make a big difference in the sound?
I'm looking at some klipsch speakers, particularly the sf-3 and the rf-35. Supposedly they're he exact same speaker but the sf-3 has a paper composite woofer, while the rf-35 has a gold woofer.
Will the difference in sound be noticable??
post #2 of 6
i am able to get the following setup for arounf $ 900
Fronts: Klipsch rf-3
Center: klipsch SC-1
surrounds: klipsch SS-1
Subwoofer : KSW-10
is this a good deal for this system?
What is the difference between klipsch's synergey and reference lines?
post #3 of 6
There are many differences in the two lines. The Synergy line uses aluminum tweeters and the Reference line uses Titanium tweeters in the horn/ The copper woofers in the reference line are much more rigid, lighter thus creating a tighter bottom end.
Hope that helps.
post #4 of 6
Driver material itself isn't as important as driver design and implementation. IOW a cheap copper/aluminum/poly cone driver with a poorly integrated, lousy crossover won't sound as good as a well designed paper cone driver with a good crossover.
post #5 of 6
All other things being equal (crossover, cabinet, etc) can a metallic woofer achieve lower frequency response than a paper cone woofer of the same size?
post #6 of 6
I think the lighter, more rigid materials lend themselves to faster transients and lower distortion rather than being able to plumb the lower depths. I may be wrong though.
  Back to Forum: Speakers
