Originally Posted by
estoyloco
All those people having problems here are some questions:
1) are you all using the premium with made up A/V cables for optical?
2) if you have you tried it with just the HDMI?
I have the Samsung HL-T5075S and the xbox premium
When hooked up with just HDMI it does not restart when I switch channels and works perfectly fine.
However, when I use HDMI + modified AV cable for optical it restarts.
Hi,
I have exactly the same behaviour. A premium xbox which is connected directly with HDMI cable to Panasonic TH-42PX70 tv. If just HDMI is used, I can change between inputs, no problem. But if I have also original component cable connected, switching input away and back resets xbox. The reset happens when changing back to xbox input.
My _guess_ is that this has something to do with the fact that there are two different video cables connected at the same time. Maybe the box switches to component and then back to HDMI which causes the boot. Just guessing though. If somebody could get their hands on to official audio only module and confirm that it works correctly with premium while using HDMI for video. And if it could be bought without that expensive HDMI cable... 3rd party manufacturers, we're waiting!
