Originally Posted by
Black993
BUMP. Can anyone assist with this connector?
I got a really busy day job. So, you gotta give me a chance to get home before I can get to these things.
Anyway, I can't see the other row of connector pins and that is the interesting side. You'll need to push the connector out of the metal shell to get to the other side. The 3 white wires on the right hand side, are pins 25, 27 and 29. You definitely need those 3 wires, as you already know, but you also need 2 jumpers on the other row of pins. That is, you need a jumper from pin 18 to pin 20 and a jumper from pin 22 to pin 24. If you flip the connector over and starting from the same end that has the toslink optical connector wires, the pins are numbered 30, 28, 26, 24, 22, 20, 18. If I have to guess, I'd say that there will be a jumper from pin 26 to 28 and this will need to be cut or removed entirely. Then add jumpers 18-20 and 22-24. You can just blob some solder bridging the pins if you like.
Any other wires not mentioned, can be removed.
P.J.
