Originally Posted by razorbackfan
ThomasAV
My brothers father in law just got 6T6. I have the ascend 340's. I have spent time with both. I have been looking at upgrading my 340's. If it was me I would get the ascends and the ed sub. The only speakers I have listen to that was way better than my ascends was some 3,000 and 12,000 B&W. I have also seen inside both speakers and the ascends drivers and crossover are in a different class like the tweeter is a SEAS design that David worked years on getting just right. Not saying anything bad about ED stuff love their subs and I'm about to get one myself. But if you want Ed speakers I would get the W6 - 6TC with stands.That will get you close to the ascends Sierra-1. That's just my two cents. And I hope it helps you.
ThomasAV
It's all opinion and I think based on your receiver, your room acoustics, and of course, your ear. I first tried the Ascend 340s in my room with my receiver and my ear. They sounded great. I had no problem with them. I then found the eD thread and began reading all the great reviews. At the time I was looking into them (2007), the cost of the eDs were considerably less expensive than the Ascends. So, I tried the eDs, knowing that I could return them. After trying them out, I preferred them much more than the Ascends, which is why I kept the eDs and did not go with the Ascends. You can't go wrong either way though.
). I ended up getting three of the A6 - 6T6 - MTM, and two of the A3 - 5TC. They also had the diy subwoofer kit in their demo room, it sounded very good for a sealed setup. I'm just waiting on the mounts and wiring for my setup so I cant really say much about the speakers themselves other than what I witnessed in the demo room, which I obviously liked. Now I just need to decide on a subwoofer, which is almost impossible with all the options eD has. If they don't have what you want they will either help you build it or build it for you, very helpful and friendly people.
