Originally Posted by
Martycool007
Thanks for the reply bro. Regarding the AE TD12 driver, is it better than the Kappa Lite 12inch driver? Or are there any other high quality drivers you might recommend?
I am not even 100% sure that I want to upgrade my home theater at this moment. I am planning on either upgrading the ht or my 2 channel system. Right now I am just gathering info so that which ever way I decide to go, I can say that I researched it as much as possible and got lots of opinions!
Please keep in mind that I am anything but an authority on speaker design. Heck, I've never even built anything but a few subs.
With that out of the way, the TD12 does measure exceptionally well, but it does sacrifice some sensitivity in the process. Power is pretty cheap though so I don't know how much of a downside that is. Btw, I'm pretty sure
this is the Eminence driver in the units that MKTheater owns. The Eminence driver does look pretty good so I'm not sure just how much one gains by using the AE driver over the Eminence. Two other high quality 12" drivers that Im aware of are the
B&C 12TBX100 which Earl Geddes uses in his Abbey and the
JBL 2206. I'm pretty sure any of these would make an excellent speaker mated to the DE250 tweeter.
Happy hunting.
