AVS › AVS Forum › Blu-ray & HD DVD › HD DVD Players › **Official Toshiba HD-A35 (ONLY) Thread**
**Official Toshiba HD-A35 (ONLY) Thread** - Page 64
post #1891 of 4859
Originally Posted by DarkKnight2k4 View Post
Got a 35 for Christmas !!!!!
Congrats! Great player..
post #1892 of 4859
Originally Posted by browninggold View Post
Downloading Nero as I am typing this. Tried that a couple of days ago but the Toshiba could not read disc. Trying the download now also through ethernet 26/39 hopefully it will make. Having the church congreagtion praying about it.
browninggold
Yes, But I had to burn a disc actually a CD-R/W most have been using the CD-R disc. with success. I tried 2 times with Nero and they were unsuccessful, I did switch over to active@ISO burner 1.1 to burn the disc at 2x speed and it went slick as dog doo-doo. It appears that Nero would not burn it at a slow enough speed. That does appear to be weird though because other posters have burned with other burners and had success. I think that's what is so frustrating about this stuff the inconsistency's The good news is I have now viewed 12 HDs with no problems.
Good Luck
post #1893 of 4859
Originally Posted by cappyxavs View Post
as stated monoprice or bluejeans...
i have monoprice premium 24awg 1.3a cables. 6' lengths are 15 clams.. they look exactly like the monster version which sells for 160 clams in big box stores and perform flawless.
someone else tried this and found out cable is cable however there is always a chance your cable could be damaged.
OK.. next step taken...
I just ordered a set of these MonoPrice 1.3a cables.
After they arrive, I'll report on what if any difference is made.
Again... thanks for the suggestions, folks.
It's truly appreciated.
post #1894 of 4859
I'm having a problem with the "Digital Direct Audio Mode". I have this turned on so my receiver (Onkyo 805 via HDMI) will decode the sound. Sometimes the selection in the menu seems to be turned off, even though it's not. I can watch a movie sometimes and cycle through the sound options (PLIIX, Cinema, Pure Audio, etc), but DD+ or DD True HD (depending on the movie or sound selected from the menu) is not an option. If I stop the the A35, go into setup, the setting shows "on". If I change the value to "off", then back "on", and start the movie again, it will default to the correct sound option (DD+ or True HD). I can then cycle through the different options if I want, and those options will always be available.
So it seems like the value is turned off, but is shows "on" in the setup menu. Does anyone else have a problem like this? I hate to return it, because it plays everything I thorw at it.
I've also had one instance where the player didn't sync with the TV (Sony 60A3000). I play it at 1080p24, but one time it only started up at 1080p60. Not sure what happened there.
post #1895 of 4859
I believe if you hit the audio button on your Toshiba remote you can cycle through until you get the sound field you want if it is avaliable.
post #1896 of 4859
did you ever read the post i left for you? if not here is a link for a iso program. be sure to down load the correct version for your os. this is the easiest method i tried that internet jusk before i'll just burn a disc
http://isorecorder.alexfeinman.com/isorecorder.htm
post #1897 of 4859
Thanks wvasko for the advice. Looked at the disc brand new yesterday and it has a couple of smudges on it. Did you do updates to your player or still 1.1? Will that help the "freeze ups" I am experiencing if I update to 1.3? Thanks
I updated my to 1.3 and played Bourne U and Harry Potter no problem.
post #1898 of 4859
Yeah, bubt it does not tell me what audio it is on. That's the only thing right now I don't like.
post #1899 of 4859
If you hit the display button twice it will tell you what audio is either being output or decoded.
post #1900 of 4859
i had the same issue. it seems as though on ocasion the a35 may send lpcm instead of bitstream... why who knows? best bet is to check the status screen of the a35 or the display of the 805 and insure it is bitstreaming. if not stop the unit and re-start. this is better than finding out half way through the movie and you have to stop and scan back to where you were. this happened to me on transformers and my fw is 1.3 these glitches make me really appreciate my panny bd30.
post #1901 of 4859
No luck with update today... so, maybe tomorrow....
Ok, so what do you suggest the settings should be on this bad boy ?
Runnng this hdmi into my Onkyo 805
post #1902 of 4859
Ok so I just spent the last few hours reading and searching this thread. I have an Onkyo 805 (no REON or upscaling) and plan to get a Panasonic plasma that will do 1080p/60 but no 24fps. How annoying is the 1080p/60 glitch gonna be? What would be the best setting for the A35? I haven't actually got the A35 yet either. I was planning this with a PS3
post #1903 of 4859
My first experience with the A35 was not the best as it would crap out on Batman return while my a20 had no issues.
Am happy to report that I watched the Matrix trilogy, bourne ult and tranformers with zero issues all movies looked amazing and the sound was insane.
post #1904 of 4859
I used Nero to burn the 2.7 firmware for my A2 several months ago and it worked great. I burned it at either 2x or 4x.
post #1905 of 4859
personally i have an 805 and all of my settings are set to bitstream everything and there is another item "digital direct audio mode" is set to on. and enjoy the bitstreaming of the hbr codecs. i locked my resolution at 1080p.
post #1906 of 4859
i have a panny plasma/60 and don't notice anything. one thing i have to give to panasonic is they really make one heck of a tv and the quality is a-1. the next flat panel plasma i buy will be a panny for sure!
post #1907 of 4859
LOL. I wouldn't call it a "glitch." It's how you've been watching movies on TV for your whole life so far. Like cappyxavs I have a Panny plasma, the TH58pz700u, and the A35 along with my PS3 look amazing on this thing. Motion looks like it always has on TV, only much clearer, brighter and more colorful.
post #1908 of 4859
Thanks ChrisO. You have the exact TV I am planning to get. Also thanks cappyxavs for your response. I think I am gonna order this thing from Amazon tonight
post #1909 of 4859
Anytime. I'm sure you'll love the TV. And the A35. And the PS3.
post #1910 of 4859
Yes sir, that's kinda what I was talking about on my post, I did not even do the last downloads and burn with Nero. I had a close friend who is a PC whiz and is in charge of our county's computers. A true geek, and he had no success with the 2 CDs he burned for me. But when I used the active ISO burn program it worked. You know what though, anybody that has tried to burn anything to a CD probably has made a lot of small useless Frisbees. Oh yes I also have the Nero 7 Ultra edition program that I tried before my buddy did on the county PCs. My wife purchased me a Halo 3 Xmas present. 1st when I popped it into my X-Box It would not play it said I needed an update. I do not play on line. I just wanted solo game play at home. I eventually got it working. The point is that the average person buying any of this stuff may not know that you have to try all this stuff again and again etc. Sorry I'm venting did not mean to get off A-35 and and into general electronic use. Don't even get me started on our new coffee brewing machine. (What use to be a coffee pot) Back to my player, it has been a smooth as silk performances since FW upgrade and that's the good news, again 12 DVDs with 5 freebies coming and 2 ordered from Amazon.
post #1911 of 4859
glad to help.. would you order one for me too
post #1912 of 4859
don't know if you are using this or not however i made a few coasters with my a2 until i got it right. this little program works sweet: be sure to use the one that fits your os.
post #1913 of 4859
Active@ ISO Burner 1.1 is one I used that worked great a freebie also. I like freebie programs that work even better. I will keep link of ISO recorder v2. A lot of these last few posts have been covered by much earlier dated posts but it saves new people a lot of reading and hunting especially if you are fooling around with your new toy. You know how that is.
Thank you
post #1914 of 4859
Hello:
Is the issue with the CD upgrade that people are simply copying the ISO file to a CD rather then using a program (like NERO, etc.) to 'expand' the files in the iso image to a disk?
Splotto
post #1915 of 4859
Yes and appreciate the information. Its a looooong story why I did not burn to disc but anyways finally downloaded with the ethernet. Thanks again to everyone-Its a War out there...
post #1916 of 4859
Ok, going to try the update on my new A35....
But I thought I would ask...
With my A35 running into my Onkyo 805... what are the best settings to have ?
post #1917 of 4859
I just got my A35 for Christmas too. Now if my Integra DTC-9.8 would show up, I could put my system to work! =)
post #1918 of 4859
I have the Onkyo 705 receiver and I love it (I'm waiting for my A35 to arrive). I can only imagine how much you're going to love Onkyo's higher end DTC-9.8. Enjoy!!
post #1919 of 4859
I recently purchased a Pioneer 94. What should I have the audio settings at in this plyayer to best utilize this receiver?
post #1920 of 4859
bitstream via HDMI
  Back to Forum: HD DVD Players
