post #1 of 1
Does anyone know exactly how the CCA in the service menu works for the Mits?
..I remember reading that with the Samsungs, you shut it off (I think) make changes and then record them and then turn CCA back on and input your changes you recorded..
My Mits65833 has a default of 1 on my set..so I know changing it to 0 will actually close out some of the SM parameters, and when I got back to 1, they reappear.Im curious..again..How would one utilize the CCA on a MIts and when which point of the calibration..
