AVS › AVS Forum › Blu-ray & HD DVD › Dual Format Players › LG BH200 Owner Review
LG BH200 Owner Review - Page 8
post #211 of 2652
I am going to bring one of these home tomorrow to test out. What should I look for?
I will be trying the 24fps with my Sony Black Pearl and I have the Integra 9.8 so I will be trying all the latest HD/BR audio formats.
post #212 of 2652
The 24fps thing is a lost cause right now. It is not working. Not enabled. Not present. Nothing to try. No one with a set that can do 24fps gets it out of this player.
The lossless codecs do not work at full capacity either. Equipment does not matter. Only lossless that works is PCM which is not really a codec it's an encoding scheme.
DTS HD MA is output as plain ole' DTS (core).
Dolby True HD is decoded in the player and output as 2 chan PCM.
Just wanted to set expectations.
All you really need to check is that discs work, ie. navigation, and look for stuttering and dropouts while playing. My experience has been that these are minimal at worst.
So far video quality is not an issue with this player with regard to highdef media.
post #213 of 2652
NOTE:
While I *HOPE* that lossless codecs are output and I *HOPE* that 24p is enabled but please everyone take note that the specs sheet now no longer lists 24p as a capability and that the HD lossless codecs capabilities are described correctly.
YES, this has changed from what was said previously. Now, it seems, LG has not committed to providing these capabilities at all.
post #214 of 2652
HyPyke,
Does the player have a Toslink output? How about an RCA Coax output?
What type of audio output can the player send through either the Toslink or Coax output? Standard DD 5.1?
I am not that concerned about the newer audio formats, as I don't plan on upgrading my surround processor.
What would be the visual difference between 1080p24 (which the player does not output) and 1080p60 on a Pioneer Kuro?
post #215 of 2652
Originally Posted by DANewsome View Post
HyPyke,
Most of these questions can be answered by looking at the specs and pics here - http://us.lge.com/SuperBlu/
Quick answer - Toslink only.
It will reencode most formats to DTS for you if you configure it to. Get the manual from the real LG site and there is a chart in the back. - http://us.lgservice.com Click on owners manuals and then "DVD&..."
Um, not sure how I could answer that. In general 24p out to a set that can display it as a multiple of 24 (48, 120, etc) yields smoother motion.
post #216 of 2652
I'm going to be returning my bh200 tomorrow.
Watching Spider-Man 3, had drop out 2 minutes in.
Down the road I'm sure these issues will get fixed, but for now the unit feels to premature.
Its a shame, the video quality is really quite nice. Its so sharp that I can tell the difference quite easily between MPEG-2, MPEG-4, and VC1 encoded Blu-Ray discs.
post #217 of 2652
Hi Everyone,
I just noticed that LG has removed the firmware update that was posted on the service site for the BH200. I hope maybe they are going to release a new update with the fixes that are neccessary to make this unit a "Home Run"! Fingers are crossed, toes too!
post #218 of 2652
Originally Posted by suntanjam View Post
Hi Everyone,
Not likely. I sent an e-mail about the 24fps, HD audio and Clerks 2 issues to LG Canada, who said they do not support the BH200 and forwarded my e-mail to their US counterpart. I got the following response (emphasis added):
"We are delighted to hear from you as our Valued Customer.
According to the information we have, regarding this unit and its interactions, the model BH200 does, in fact, display at 24 frames per second, if the display is capable of 24 / 30 fps. We do not force 24 fps, nor are there currently any designs to do so anytime soon. As for the Linear PCM, as long as the disc is formatted for the full 7.1 audio, then the settings for Linear PCM will output 7.1 audio through either the HDMI 1.2 or HDMI 1.3 versions. The Dolby TrueHD audio is designed for 2 channels of sound on this unit.
As for the movie Clerks, this video has been tested and found to have a new copy protection that is not allowing our units to play back. We are currently working with our factories to develop a firmware upgrade to resolve this matter. ..."
I have an Sony 52XBR4 and the 24 fps detection works perfectly for both my PS3 and Samsung 1400, so I'm pretty sure my TV is "capable of 24/30 fps". From the above, it looks like there are no plans to enable 24 fps in the near future. The full multichannel Dolby TrueHD appear to be limited to 2 channels and the person didn't even address DTS-HD MA. The good news is that LG is working on a fix for Clerks 2, so they might have took the firmware offline for that. I thought the HD DVD standard was finalized though, so I'm not sure what "new copy protection" the rep was talking about.
Looks like I'll be returning my player tomorrow...
post #219 of 2652
Um, that is wrong. If that were the case then why was it REMOVED from the spec sheet? It was there in previous versions and specifically removed. LG support is full of ****.
Thanks for the report UFE. I appreciate it.
post #220 of 2652
Hi Everyone,
For everyone just joining us, please note that the firmware is still available on the Canadian site as well as a few other regions with English language text. It was only removed from the US site it seems. Since it was a month old when it was released lets home a new one is indeed coming soon.
post #221 of 2652
Whoever designed it this way should be fired if true. This also means the Samsung is similarly designed since they both use the same SOC. This is the height of ridiculous audio restrictions.
post #222 of 2652
Yeah I am REALLY getting ticked. Saying it will never happen is not what I want to hear.
The unit CAN output TrueHD in bitstream mode. It is not enabled. It is essentially crippled by the manufacturer.
post #223 of 2652
I again refer to a message I put up on the last page regarding audio output. If True HD is ALWAYS going to output as 2 channel, then this is a clear case of false advertising. As you can see in my last post catalogues such as Crutchfield CLEARLY tout this machine as one that can decode ALL the new codecs including True HD. The manual shouldn't be allowed to display these codecs the same way it was prohibited from showing the Hd DVD logo on the BH 100 machine. I plan on calling LG and telling them to have all the electronics outlets and websites state the truth about the audio of this machine. That said I don't have HDMI on my tv and the bh 200 has been performing very well when it comes to the video picture for both formats and for the audio of regular dolby digital, DTS and even the few dvds that are being decoded as dolby digital plus.
post #224 of 2652
Well, the problem would be Crutchfields not LG. They no doubt based the catalog description on the early specs which said it would do multichannel. The early specs came out before the machine was actually released so LG was not really committed.
The manual can display the logo because it DOES decode TrueHD. It just does only 2 channels. TrueHD was designed to allow the players to decode only the channels it needs/wants according to the Dolby site.
From the TrueHD faq at Dolby.com:
18. Will all new players equipped with Dolby
TrueHD support the maximum channel
capability of Dolby TrueHD?
The Dolby TrueHD stream is structured so that
a player only needs to decode the number of
channels it needs. This ensures that a single
Dolby TrueHD stream can be used to deliver
a two-, six-, or eight-channel presentation
with precise control over the playback defined
by the content producer.
Also, The HD-DVD spec says that only 2 channels need to be decoded in order to meet specifications.
I don't think you are going to get much of a response from LG support. They are not very knowledgeable and it seems that most of the decisions and software updates are made in Korea. (See the firmware release notes. Horribly broken English. Support is based out of Alabama and while they are stupid over there they aren't that bad.)
Good luck though and let us know what they say.
(I apologize for the Alabama remark but, you have to admit, it is the land of the dumb. I live in Georgia and as you drive west you can actually, physically, FEEL your IQ drop. Plus, the state smells. Seriously, the whole state. On foggy mornings the stench wafts across the border and reaches as far as Atlanta. Whoops, there I go again. Sorry. Just a little 'Bama-Georgia rivalry flaring up is all. No matter what we think of each other I think we can all agree that South Carolina is the armpit of the south, right? Oops. I am just going to stop now.)
post #225 of 2652
Ok, I have both the BH100 and BH200 in my system so I can switch back and forth between the two. The BH100 has no prblem sending 1080/24P through my Integra DTC9.8 to my Black Pearl. The BH200 only sends 1080/60P through. So it looks like no current 24Hz refresh rate support.
Also the LPCM out through the HDMI to my DTC9.8 goes to 2 channel if you switch to some other input and I have to cycle through the audio selections on the disc to get back to LPCM and then it thinks it is getting 7.1 instead of 5.1
So this new BH200 has some major issues it would seem.
post #226 of 2652
Guys,
Thanks for all of the info! It looks like I will be returning my BH200 as well. I was hoping that since this was a 2nd gen player they would have got it right. Looks like its back to 2 players and hope someone at CES shows a combo player that functions as it should. Everyone have a Safe and Happy New Year!!!
post #227 of 2652
Guys,
What are you going to use in the mean time? Sony BDP-S300 and Toshiba HD-A30 or something?
My older Denon (2807) a/v receiver doesn't to the trueHD/DTA-MA formats, but I was thinking of upgrading in the spring, so maybe I'll follow a similar path.
--Daniel
post #228 of 2652
No problem. I hope things work out for everyone here--I took the BH200 back to the retailer and got a full refund today. I was really tempted to just keep it as a crippled player in my bedroom since I got it on sale, but for that amount, I could get 2 separate BD/HD DVD players that does what I want... And the response from LG was just ridiculous! The more I thought about it, the more I felt like I was defrauded.
post #229 of 2652
--Daniel
Daniel,
I will be getting the Toshiba HD-A35. I should have bought it last week when Amazon had it for $299 with 10 free discs! Right now its at $350 with 10 discs which still is not bad. As far as Blu-ray goes, I'm looking at either the Samsung 1400 or a Panasonic. Its a shame that we have such a fantastic technology (HD DVD, Blu-Ray) and the manufacturers are doing their best to F-it-up. Dual formats, crappy players, expensive, etc.
post #230 of 2652
I take it 1119F is still the latest firmware version?
post #231 of 2652
Yes.
post #232 of 2652
Yes.
I am going to be turning over a list of problems with the BH200 to my LG rep. and this is the list I have thus far.
Feel free to add to it.
BH200 issues:
No 1080/24P output
Dolby TrueHD Only outputs as 2-channel PCM
No DTS-HD-MA
Camera ICON appears on Ratatouille BR disc (same on the BH100).
I have no HD-DVD's so I can not test those.
post #233 of 2652
Well I worked with an LG product specialist the last 4 weeks and concentrated on the 24fps issue. He was very hard to get responses from. I sent a complete set of facts of which displays would not work, links to reviews the said 24fps did not work. I kept being told it was supported and was working on one of the reps units. His last comment Dec 18 was QUOTE\\"Well, try it on a display that is 24fps only and see if it works. The unit will output whatever it needs to. It just can’t be forced to do 24 at this time." I responded with more facts and asked LG to consider it an issue that 24fps does not work at all with 1119f.
Nothing heard from LG since 18th, 24fps is not in the spec sheet (only once in manual), I've given up. Got a 5000, compared the two for about a week and returned the LG. Now with the Samsung I have 24fps, PQ is close, a few more sound glitches but at least upgraded sound (with firmware update "twice") and 24fps are supported in the spec sheet.
I feel LG will probably come around and fix the issues, but I wanted 24fps sooner then later. The rep I dealt with was going to send me the latest software but never did and he did not know 1119f was even coming. It just showed up on their site. LG is probably working on the issues but not informing anyone IMO.
For those that hang in there, I hope all goes well.
post #234 of 2652
[quote=echudoba;12630767] I kept being told it was supported and was working on one of the reps units. His last comment Dec 18 was QUOTE\\"Well, try it on a display that is 24fps only and see if it works. The unit will output whatever it needs to. It just can't be forced to do 24 at this time." I responded with more facts and asked LG to consider it an issue that 24fps does not work at all with 1119f.[quote]
Well I hooked the BH200 direct to my Sony Black Pearl and I tried all settings in the BH200 and still could not get 24fps to work so I would like to meet this "rep" and borrow his BH200 to test on my Black Pearl. Also the BH100 is still working just fine with BP @ 24fps.
Is there one person on the forum that has gotten 24fps to work with the BH200?
I see the Samsung 5000 is working with 24fps from what I read on that thread.
I will pass my list on the LG tomorrow and will go from there.
post #235 of 2652
If they have they haven't said anything. I started this thread and I've read every post.
post #236 of 2652
At the moment, I'll probably be keeping mine. It's been working well, maybe firmware updates will open up some of the missing options in the future, or not.
post #237 of 2652
So I just got my new Onkyo TX-SR705 receiver, as well as, my LG BH200. I was playing the Bourne Ultimatum in HD DVD and was wondering why I wasn't getting any Dolby TrueHD sound and why the icon wasn't lighting up. After reading this thread and learning about the 24fps issue, I am really tempted to take it back to BestBuy and go with 2 separate players. I paid $1,000 for this player and this is really a bummer.
Why would they release this new model to follow the BH100 if it doesn't make it any better?
Lastly, if I go with 2 separate players, what do you guys think are 2 ideal choices? Since I spent $1,000 on the LG, I'm willing to spend that much combined, for 2 separate players. Any suggestions?
post #238 of 2652
There is a discussion going on here - http://www.avsforum.com/avs-vb/showthread.php?t=961519
It was about the Samsung player but should still help.
post #239 of 2652
post #240 of 2652
well i picked my unit up yesterday and made a stop at blockbuster and rented 300 which i have not seen before. i disconnected my integra dps10.5 since i have only two hdmi inputs on my elite pro1130. did a quick install on the lg and popped in the blue ray of 300. like i said i never viewed this before so i don't know the quality of the movie but i was disappointed with the results. the picture was very contrasty and was a little grainy. i should have rented a stock version and tried it in my integra first at its upconverted 720p setting.
i then played my standard copy of king kong which i have watched numerous times on my integra upconverted to 720p. i can honestly report the integra put out a better picture, more depth and color, than the lg. i will have to invest in a hdmi switcher and keep the integra connected for watching standard dvd's upconverted to 720.
i will rent a copy of rush hour 3 todat in blue ray or hd today and see how that plays and report back.
one note though, i'am have the output set on the lg to 720 to match my pro 1130hd. i may not see the full potential of the machine until i move up to a 1080p set which i plan to do in the near future (pdp6010 kuro)
  Back to Forum: Dual Format Players
