AVS › AVS Forum › Blu-ray & HD DVD › Dual Format Players › LG BH200 Owner Review
LG BH200 Owner Review - Page 88
post #2611 of 2662
Originally Posted by HB GAMER View Post
yes
How does one do that? I have my BH200 with the latest FW connected to Panasonic AE2000 projector. The player outputs 1080p24 with Blu-rays but 1080p60 with HD DVDs. Since HD DVDs do not have a flag to tell whether the encoding is film based or video based, the player would have to be capable of determining this based on cadence. Toshiba HD DVD players could not do this and had to be set to 24Hz output manually.
post #2612 of 2662
I have the exact setup as you with an Onkyo 605 receiver between them.
From my experience some imported HD DVD's do not have the 24hz flag or the lg does not check properly. Most, if not all, domestic HD DVDs that I have play 108024.
post #2613 of 2662
This is probably because PAL-region imports can be encoded at 1080p/25 or 1080p/50.
post #2614 of 2662
This was with US release of License to Wed, which also happen to be the first HD DVD I've played on this player. My XA2 gave me the dreaded 4xxxxxxxx error 1 hour into the movie and I had to use the LG to finish the movie.
post #2615 of 2662
try another movie and it should work just fine. I have not watched license to wed so I cannot verify.
MauneyM, you are probably correct, as I am just speculating.
post #2616 of 2662
Licensed to Wed worked fine on my player about 6 months back. Should be fine.
post #2617 of 2662
Did it playback at 24Hz? Mine would only playback at 60Hz.
post #2618 of 2662
BH02081205A firmware is now posted on LG's web-site.
post #2619 of 2662
I tried this last night with bunch of HD DVDs. Everything else I tried played back at 24Hz. License to Wed for some reason would only play back at 60Hz. I'm wondering if there might be some sort of authoring error.
post #2620 of 2662
I dont get the whole thing with 24Hz... I mean I know the films were filmed at that speed so technically thats as many FPS as your going to get without some blending of other frames or something like that to get higher Hz. but I just despise the choppy nature of film like that. you can hardly see action scense at all because of this. its like playing flight simulator 2009 on a 5 year old pc with integrated graphics. I suppose it simulates the look/feel of film but I think it looks like crap. IMHO
post #2621 of 2662
They should come out with 48hz! double the frames!!!
post #2622 of 2662
serious!
post #2623 of 2662
Originally Posted by aaronwt View Post
Is there a problem with the BH200 and 5.1 pcm content? My Denon 3808 shows it's receiving 7.1 from the BH200 when it should be 5.1.
I tired one 5.1 96khz/24bit track. The 3808 showed it was receiving 96khz/24bit but it also showed it was receiving 7.1 instead of 5.1.
I also tried a few other 5.1 48khz tracks and those also showed up as 7.1 instead of the proper 5.1. None of my othe rplayers have exhibited this problem.
Aaron, I'm glad you posted this. My BH200/AVR-3808 combination exhibits the exact same behavior. Did you ever get this figured out, or is this just the way it is?
post #2624 of 2662
I think there are some problems with the BH200 and Denon receivers in general, as the BH200 seems to want to punt and send my 2807 stereo when there are alternatives available.
Thankfully, the irregularities we get with the Denon/BH200 combination aren't as annoying as the dropouts and pops other people seem to have with different brands. If I occasionally have to monkey with the sound settings that's OK. As long as the audio sounds good overall.
post #2625 of 2662
I have a DENON AVR5803 and I have no problems with receiving DD 5.1!!!
post #2626 of 2662
whats the firmware update for ? and can you post a link for it cause i cant find firmware upgrades for the player on the LG site.
post #2627 of 2662
The reason it looks like crap on your TV/projector, but pretty decent in the theatre (at least when it comes to film projection), is b/c your TV/projector likely doesn't replicate the effect of a split second (1/24th of a second) of darkness in between successive frames. It is this darkness b/w projected frames that prompts the brain to interpolate/compensate, thus making motion scenes quite palatable.
Note that the interpolation function on many modern TVs (motionflow etc... particularly common in LCDs) where 1 or more extra 'frames' of interpolated information are created/inserted in between the original 24Hz material is not what I'm talking about. While the latter may give you a smoother experience, particularly in motion intensive sequences, it isn't free from artifact, and often makes everything look like HD Cam.
To replicate the look of projected film (and its benefits with motion intensive material), you need either (i) a CRT projector (where the natural periodic decay characteristics of the illuminated phosphors replicate the on/off nature of projected film, or (ii) 'dark frame insertion' a la that featured on the Sony VW200 where a black frame is inserted in b/w each original frame. That said, there is no free lunch, the latter results in a dimmer image.
The reason more displays haven't incorporated dark frame insertion anywhere near as much as motionflow is b/c (sadly) to the average Joe, a brighter/punchier image trumps all, irrespective of deviations from a true cinematic experience.
post #2628 of 2662
* Where do I find the latest Firmware BH02081205A (2008-12-05)?
Go to:
USA - http://us.lgservice.com/
Canada - http://ca.lgservice.com/
UK - http://gb.lgservice.com/
Belgium - http://be.lgservice.com/
Switzerland - http://ch.lgservice.com/
If your country isn't listed, go to: http://www.lgservice.com/
Then:
USA Site:
1. Enter BH200 into the Search field on the front page.
2. You will be presented with a list of BH100/BH200 downloads, the highest BH100/BH200 link in the list is the latest firmware.
3. In this case you need to click on (US Only) Program Update for BH200, with the size 37,923K.
4. You'll then see the Firmware name (BH02081205A) and various download links, download both files:
LG_BH_LV221BH.zip and Update Guide for BH200.pdf.
Other Sites:
1. Click on DEVICE DRIVER, then click on DVD&VIDEO&SET TOP
2. Click the Search button
3. You will be presented with a list of BH100/BH200 downloads, the highest BH100/BH200 link in the list is the latest firmware.
4. In this case you need to click on (US Only) Program Update for BH200, with the size 37,923K.
5. You'll then see the Firmware name (BH02081205A) and various download links, download both files:
Instructions:
1. Unzip the file LG_BH_LV221BH.zip - The file you need to transfer to a CD/DVD/USB Stick is called LG_BH_LV221BH.ROM.
2. Follow the instructions provided in Update Guide for BH200.pdf
IMPORTANT: Before transferring the LG_BH_LV221BH.ROM file to a CD/DVD/USB Stick make sure it's size is: 38,820,748 bytes.
post #2629 of 2662
Go to:
Then:
USA Site:
Other Sites:
Instructions:
ok thanks
post #2630 of 2662
You're Welcome!
post #2631 of 2662
You're Welcome!
been along time since ive used winzip where in winzip do i click to unzip the file ?
post #2632 of 2662
I am considering buying a BH200 for the dual playing ability. However I already have an A30 and so should I just buy something like the Sony 350 and give up the idea of a dual machine? That way I get the newest blu-ray technology but I give up dual play and have to house two machines.
The Sony 350 and the BH200 would be about the same price.
post #2633 of 2662
It all depends if you want or need a back up HD DVD player. By buying the LG BH 200, you can keep your A30 as a back up and enjoy Blu on your new BH200.
But if you need 2.0 grab the 350.
Cheers
Struggo
post #2634 of 2662
I think this idea has merit, if you don’t mind having 2 machines in your AV cabinet and juggling disks between them. I did this for a while during the format wars and invariably put a Blu-ray in the HD-DVD machine and visa versa. It was a pain; the BH-200 is simple one stop shopping.
Also keep in mind that over time your HD-DVD unit will gather dust, as an ever increasing percentage of disks will be Blu-ray.
A_C
post #2635 of 2662
Originally Posted by Agent_C View Post
I think this idea has merit, if you don't mind having 2 machines in your AV cabinet and juggling disks between them. I did this for a while during the format wars and invariably put a Blu-ray in the HD-DVD machine and visa versa. It was a pain; the BH-200 is simple one stop shopping.
A_C
I dunno. I have a Panny BD35 in my family room and the LG BH200 in my movie room. The Panny is rarely used and the BH frequently. Why is dust settling on the Panny and not the LG. Simple. I have ammassed a large collection of HDDVDs (classics and favorites), by buying them highly discounted (some at around $4.99), and by picking up freebies from friends and others who abandoned the format. I just will not invest a ton of money in a format (BR) when discs of all kinds already have the writing on the wall. I am streaming Netflix SD and HD will be around the corner, so owning discs will be an anachronism. None of my adult children, who are all techies, own any discs of any kind. from IPOD to Bit Torrent, hard drive copies suite them fine. And when I rent a BR from NetFlix, I play it on the LG anyway, as it does a great job of sending a bitstream to my receiver for the lossless codecs. I for one have no interest in BR live, am not angry with LG, paid $400.00 for my machine and gor $75.00 back, and received the December firmware update unsollicitted in the mail. (It pays to register).
So although others feel differently, I believe my LG is one of the best bargains and performers in my collection of parts and pieces that contribute to my 3 home theaters. I would encourage anyone that can get one for under $500.00 still, to grab the puppy, and enjoy it. Unless you want to use it for the Interent which I don't. Just my opinion, but I thought the other side might be helpful.
best wishes,
Barry.
post #2636 of 2662
Originally Posted by bjmiller48 View Post
I play it on the LG anyway, as it does a great job of sending a bitstream to my receiver for the lossless codecs. best wishes,
Barry.
Out of interest, what AVR are using Barry?
Cheers
Struggo
post #2637 of 2662
Cheers
Struggo
Onkyo TX SR-606, avilable for $325.00 in the USA. I pride myself in being a bargain hunter, and this little gem and my LG BH 200 are two of my biggest bargains. (The LG cost me $325.00 after rebate.
Best wishes to all of you down under,
Barry
post #2638 of 2662
Barry
Thx for the feedback Baza
I have enjoyed my BH 200, although I have always ran the audio into my old Yamaha via optical, DTS Re-encode.
My concern is when I upgrade my amp, I will have nothing but trouble.
I'm looking at the following,
Sony STRDA2400ESB or STRDA3400ESB
or
Onkyo TX SR-606
Will these amps run without issue with my BH200?
I'm also unsure why the displays resolution would effect the HD audio. I'm have a Hitachi 1080i display.
Cheers
Struggo
post #2639 of 2662
I didn't mean to suggest that video processing would in any way affect the audio, just that if you use HDMI for video to a receiver, you bring the audio as well and have the option of using the lossless codecs from the bitstream of the BH200. Only HDMI will allow you to use these knewer much discussed codecs.
I for one am unable to hear the superiority of the lossless codecs (DTS Master etc), when all other factors are adjusted to the same level, such as volume etc. I have switched out the HDMI audio with the optical, and although they are different, I couldn't say one is better than the other. I have a dedicated audio room, with Maggies and Bryston electronics and consider myself to have as good a "golden ear" as anyone. I do an aweful lot of dedicated listenung in stereo, DVD Audio and SACD in my audio room. Yet, I can not hear the superiority of the new codecs.
Home Theater magazine (March 2007, I believe) ran such a test with the writer and editor as listeners, and they also could not say which was which, in the Dolby and DTS studios.
I never tell people to upgrade for the sound alone, but many people disagree and feel I am wrong and have said so. I am comfortable with that.
Hope that helps,
best wishes,
post #2640 of 2662
Hope that helps,
best wishes,
Thx for the feedback.
My BH 200 is currently running DTS re-encode. I think it is fantastic.
The thing I probably miss most on my 8 year old receiver is Dolby Pro Logic IIx.
Cheers
Struggo
  Back to Forum: Dual Format Players
