AVS › AVS Forum › Blu-ray & HD DVD › Dual Format Players › LG BH200 Owner Review
LG BH200 Owner Review - Page 20
post #571 of 2662
Originally Posted by StardustOne View Post
Just unpacked and hooked up mine.
Cool device! Excellent built and extremely quiet.
Hmm what's the deal with that green line during DVD playback? It's visible in 1:1 pixel mapping mode (true or exact scan, overscan disabled) on my Full HD 1920X 1080 panel and is constantly dancing and flickering during playback.
Any chance to get rid of this green line? My unit is from January 2008 (sticker on box) and I am very disappointed that they didn't even dare to fix this. Can't this be fixed?
I imported mine from the USA and sending it back for repairs would only be a last resort option.
OK..I have same issue January 08 build date. I contacted LG and they told me that they have not been able to duplicate this green line (BS) and I would have to send my unit back for serivce under warranty for this. Since, I am starting to not believe in a company that ships defective and not ready product to their customers and since HD palyback is fully OK at this point, I am thinking I will quit while I am a head and just use my overscan setting when watching a SD DVD. This gets rid of the green line and also removes some (not all) of the letterbox bars. The chance of LG sending me a unit that plays all HD disc as good as this one is not very likely and I am not willing to take that chance.
post #572 of 2662
I have to admit I am trying a samsung 5000 on Monday. The audio dropouts only happen when in HDMI PCM Stereo mode but that is all we can keep it in since it is only hooked up to a plasma. I will sell my BH200 so if anyone wants one cheap without using paypal let me know... Send a PM... And yes it would come with everything. It is actually a Jan/08 unit...
post #573 of 2662
With my problems and others, I think LG had better quickly do something. If this machine gets a reputation of being defective, LG won't be able to sell them.
post #574 of 2662
Just so you know, the 5000 isn't completely devoid of audio dropouts. The main culprit is standard DVD with Dolby Digital. Only 2 out of several dozen high def discs (both HD DVD) have exhibited any dropouts in my experience. YMMV.
post #575 of 2662
Considering I have tried 3 separate LGBH200s and all had audio dropouts I will take my chances...
post #576 of 2662
Sorry the LG did not work out for you. Good luck in finding a unit you like.
post #577 of 2662
Thanks, if they ever fix the audio dropouts I will get one. I could have lived with it but it was a Wife issue since she uses it a lot. If the Sammy does not work then I guess it will be time to put 2 players in there...
post #578 of 2662
Oh this is so plain weird, just tell those guys that they have to check for this DVD green line playback issue by using a Full HD panel and they have to set it to 1:1 pixelmapping (no Overscan). Are those guys really that plain stupid that they even can confirm their own design errors?
This affects all the BH200 ever produced and it will until they are going to address this with a firmware upgrade, it plays back HD DVD and Blu-Ray just fine, why can't they fix this? It is a simple glitch in the DVD upconversion process, nothing that couldn't be fixed, I am sure the hardware does not require maintenance.
By the way, it is not just the green line in the upper right corner, it is the entire top row, probably 4 rows of pixels that don't display the picture correctly. If and only if the Overscan is disabled.
post #579 of 2662
Originally Posted by zaragoza View Post
Honestly, I'm a little disappointed of my BH200 video dropout problem. If this will happen again today, I would definitely return it instead of having it fixed by LG. It's a good thing that I'm still within the 30 day return period. I pretty much have a good "keep it / return " ratio on electronics where "keep it" is always the case. But lately, it seems like I'm more on the "return" mode. It started with Sharp BD. I returned it because it wasn't HDMI 1.3 and they showed it as HDMI 1.3 in their website. Then the LG BH200, I took the only stock left of it at BB thinking it's a good buy at $699. But I'm wrong, maybe that's the reason they put it on sale. If this(BH200)is returned, BB must be pissed with me. I may give Panasonic BD30K a try. It's a good match to my 50PZ77U.
Didn't work for me. Got two and all had video and audio dropouts. I have video dropout when it's connected to my Yamaha RXV1700 via HDMI. I did a workaround and connected (hdmi) it direct to my Panasonic Plasma, audio dropout happens.What a painSo, off you go and welcome Panasonic BD30. And, no problem so far I'll just use my ever trustworthy Toshiba HDA2 for HD DVD's.
post #580 of 2662
That's so weird. I have yet to see this green line. Is this only an issue with flat screens? I have an LED DLP and it has yet to do that.
post #581 of 2662
Sorry if I am asking the obvious. I've searched through various threads but cannot find the answer:
1. How many different firmware has LG released for the BH200?
2. When was the last firmware released?
3. Does it fix most/all disc playback problems?
4. How bad is it still?
5. Is it true the BH200 is Profile 1.1 or not? I've read reports it is Profile 1.1 but also it needs a firmware upgrade.
Thanks in advance.
post #582 of 2662
Well, last night I played a normal DVD in the unit. I think I had 10 audio dropouts. No video dropouts however. It seems the video/audio dropouts on my player are only for HD DVD & BluRay. Does LG have any kind of quality control? I can't imagine how these players were released with this problem. I think before my 30 days are up with the retailer, if no firmware appears to fix the problem, I will return this defective equipment.
post #583 of 2662
I did the same, to wait for fix via firmware. Then, decided to return it once and for all after calling LG tech. This is their answer after telling them about the audio/video dropout problem, " Sir, I'm sorry to hear that, but we haven't received any complaint yet about the problem you just mentioned. It could be just a bad unit". Bad unit???? Maybe bad UNITS!!I had two bad units (Jan 08 built) before deciding to give up. Too bad LG!!! I'm a happy camper now with my new Panasonic BD player. I don't have to deal with those annoying video/audio dropouts. So, it's up to you decide.......Good luck!!!
post #584 of 2662
Hey there, I'm an LG Product Engineer here in the states. I've been testing the following firmware and it should be coming to the rest of the world very shortly. We do appreciate your business and I do understand your frustrations. Please do not bombard me with questions as I am very busy, but I check the forums from time to time and wanted to provide an update for you all.
osofast35801
AUDIO
DTS-HD 7.1 ch Bitstream output
Able to output 7.1ch via pass through for DTS-HD master audio source.
(BH200 R/C & 3rd Gen. OK)
DD+ 7.1 ch. Bitstream output
Able to output DD+ 7.1ch via pass through.
Dolby TrueHD 7.1ch decoding (PCM output)
Able to decode & output 7.1ch via HDMI as PCM output for Dolby TrueHD source.
*bitstream output is enabled in 3rd Gen. ONLY
VIDEO
1080p24(Film Mode) output
User can now select 1080p24 output by selecting Film Mode from the setup menu.
BD 1.1
PIP Feature (Bonus View)
There are 2 BD 1.1 enabled titles out in the market as of Jan. `08.
In process of fixing issues that shows up while PIP is enabled.
SW UPDATE
Network SW Update Support
Able to update the firmware via BH200's network capability by connecting to the US server.
post #585 of 2662
The below looks great but what about dropouts. I can't watch any disks without dropouts. Hopefully, this will fix that as well.
osofast35801
AUDIO
VIDEO
BD 1.1
SW UPDATE
post #586 of 2662
Mr. Clarkson, is that you? If that's you, I have your email embedded in my inbox. I'm looking in to the drop out issue at this moment.
post #587 of 2662
Yep. I sent a number of emails because it seems I'm not the only one dealing with this. Thank you for looking into it. I really want to keep this player.
post #588 of 2662
Osofast:
That is wonderful news. Do you have any indication at all as to some general timeframe when the new firmware may be available?
Thanks. We all appreciate your hard work.
post #589 of 2662
I have the BH200 going into a Denon AVR4306 via HDMI. The denon feeds my LG 50PC1DRA plasma by HDMI. The Denon is setup to send the Plasma a 1080i signal. I thought it would be better to let the LG plasma convert down to the 768 lines rather than just send 720p from the Denon. Just as a side note, I also have a DVD/VHS LG player (I believe the model has a 544 in it). It turns on when the remote control turns on the BH200. Thats not a big deal though.
post #590 of 2662
That is great news thanks osofast35801
* What does 3rd Generation mean? Has there been more than one revision of the LG BH200?
* When will the LG BH200 come to Europe?
Can someone also answer my questions below please? -
Thanks in advance.
Regarding the Profile 1.0/1.1 status. Taken directly from the LG BH200 manual page 7:
This player supports BD-ROM Profile 1 version 1.0 only. Other profiles (i.e., BD-ROM Profile 1 version 1.1 or Profile 2) could be supported through updating player's firmware later. It may be required to update the firmware in case of playing a certain newly released commercial BD-ROM disc. For updating player's firmware, please refer to http://us.lgservice.com or contact LG Electronics customer care center at 1-800-243-0000.
post #591 of 2662
The audio video dropouts are not that bad. one to 2 seconds per hi-def title. There have been at least 2 versions of the software, public released, versions N and P. There is/was a rumor of a machine that was the bh200, plus a larger hard drive, to download movies from netflix, which was announced at CES, without too much detail. This is a great and high quality player, overall
post #592 of 2662
The firmware update mentioned by Osofast, above, is the one EVERYBODY wants. Can't wait.
post #593 of 2662
Thanks for the info hello252
I read about that new version. I don't use Netflix (I think it's North America only anyway) so it doesn't personally interest me, although it does sound interesting.
Which software is newer N or P?
post #594 of 2662
P is the latest version, available on LG's service website, which for the u.s. is us.lgservice.com.
That is, until osofast's version comes out
post #595 of 2662
Thanks again.
What discs still have problems (if any)? The rest of my questions have pretty much been answered (I'm not sure what osofast35801 means by 3rd Gen. though?).
post #596 of 2662
And to think I just sold my BH200! Of course I did go thru 3 with the audio dropouts... As soon as some folks can confirm they are fixed I would defintely try another one... As of now I am testing/playing with a sammy 5000....
post #597 of 2662
OSOFAST - That is GREAT news - we're all looking forward to the availability of that update - You don't have to comment on this, but the LG support guy (Neil) has no clue what the LG engineers are working on. He insists there are no firmware updates in the BH200's future. When these updates are installed and working, the BH200 is going to be THE machine to beat. Thanks for the info.
post #598 of 2662
Good news about the firmware update. Now if the video/audio dropouts can be corrected, as well as the SD "green line" issue, then I'm sold on this player.
post #599 of 2662
I'm also curious what is meant by 3rd Gen also!! bought my BH200 and can still return it if there is something different about the players.
post #600 of 2662
I think R/C means Release Candidate (i.e - Original Build) but 3G would imply there are three distinct models and then obviously different firmware for them on top of that.
If that's so I wonder how they differ?
  Back to Forum: Dual Format Players
