Originally Posted by
Zero/One
Where do you find this information?
On page 72 of the 110FD / 150FD operating instructions:
"Deep Color supported
Deep Color means the color depth that describes the number of
bits used to represent the color of a single pixel in a bitmapped
image. Besides the conventional RGB/YCbCr16 bit/20 bit/24 bit
signals, the plasma display also supports RGB/YCbCr30 bit/36 bit
signals. This enables finer, minute color reproduction when a
device that supports Deep Color signals is connected to the
plasma display. When Deep Color signals are received, the color
depth appears on the channel display."
It is silent as to what happens in regard to xvycc.
