So, after looking in to some non-DIY screen materials, I'm considering just doing a paint job for the time being.
I think the simplest solution for now is just to stick to the N8-like Sherwin Williams Gray Screen (SW 7071). I will have to prep the wall a bit, and will need to prime it too, since it's currently got a (very light) olive green tint to it.
In terms of both the primer and the paint, do I just simply use a 5 mm roller, with a flat enamel latex? Or 10 mm and eggshell?
The room has a white ceiling and light hardwood floors. The other walls are light olive green, I'm guessing with probably about the equivalent of an N7 darkness I'm guessing.
P.S. I don't really want to use a basic matte paint, since they are impossible to clean.
