AVS › AVS Forum › Home Entertainment & Theater Builder › Theater Room Items & Accessories › Berkline seats. What are your reccomendations
post #1 of 4
I have to build my riser and order seats shortly. Found a great deal on the 078's, but have no way of sitting in them before ordering. I have sat in the 090's and liked them. I sat in the 88's and did not like them. My choices are the 078, 090, 099. What are your reccomendations? Thanks in advance for all reponses.
post #2 of 4
I was like you about 6 months ago. I decided for me, the 45004's would fit the bill nicely. A bit smaller profile, like the 088's, but a little taller for a bit more neck/head support for myself.
Best,
Tom
Chinaclipper
post #3 of 4
John,
Search the forum, here is one search result:
http://www.avsforum.com/avs-vb/showt...&highlight=078
post #4 of 4
I actually had to drive about 3 1/2 hours to sit any in Berklines to try them out. I only got to sit in the 90s and the 88s. I ended up ordering the 45003s from rsh here on the forums without ever trying them out. I'm so glad I ordered them too, they are amazing! They look like the 90s except they have a pillow-top like back. You should definately consider them as well.
