AVS › AVS Forum › Video Components › Home Theater Computers › I'm thinking of making my next media center all external.
post #1 of 10
No Optical Drives
No Hard Drives
No Internal Tuners.
So the machine will consist of a small motherboard a cool running processor and a tiny case.
Externally I will go with a couple of HD Homeruns
An NV Nas+
And Hopefully some sort of external DVD player.
I don't know how I'm going to do it but the intention is to just have a gigabit cable and power going to the machine.
post #2 of 10
Case
post #3 of 10
do you plan to load the operating system from the network? You can also consider installing the OS on a solid state drive which will be silent and efficient.
I am curious what is the overall goal of this?
Itai
post #4 of 10
Itai
If you can really pare down the OS, you might be able to get it to run from a 8 GB flash drive. Boot times are very nice with solid state disk.
Mike
post #5 of 10
I'd probably just go with a small silent laptop drive.
- Josh
post #6 of 10
- Josh
+1
post #7 of 10
- Josh
I have a couple of those lying around so that works.
post #8 of 10
Itai
Hmm I hadn't thought about it, what would this entail?
post #9 of 10
By Decoupling all the storage and tuning I can put a completely silent and minimally configured htpc in place very very easily.
It's kind of an extreme version of my less is more philosophy.
post #10 of 10
neat idea.
another case suggestion:
http://www.newegg.com/Product/Produc...82E16856171002
it has an internal laptop optical drive, though.
