AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Sony KDL40V2500 Fast Input Switching?
post #1 of 5
Currently to switch input I have to hit the "menu" button, then navigate to "External Input" and then navigate to my desired input.
Is there a way to switch to a desired input faster?
I wish you could program a few buttons to switch immediately. My old cheapo Sharp tube TV had a better remote than this!
post #2 of 5
Anyone have any ideas?
I'm open to buying a universal remote if it resolves my problem.
post #3 of 5
All you have to do is press the 'TV/VIDEO' button at the upper left. It cycles through the inputs one per press. You can "skip" available inputs by going to MENU, SETUP,VIDEO LABELS, PROGRAM, and toggle down/up to 'SKIP', press select, press return to exit.
You can go directly to tuner input by pressing CHAN+/-
post #4 of 5
The thing is I have a lot of things connected to my TV and hitting the TV/Video button repeatedly take a long time due to the lag in switching. So I was hoping there would be something like hit input type and a number and it would switch to that....
Most likely does not exist.
post #5 of 5
I think a high-quality universal remote wil probably do it, then; as long as it has those direct input # buttons.
