Originally Posted by
NIN74
Well, speakers is one thing, but CD players and amplifiers are, with in reason, almost the same in quality today. As long one don't need 500 Watt one can get a really cheap amp that does it right.
It is a slippery slope - about what you can hear and what you think you can hear! I might grant you on CD transports, but once DACs come into the equation, well, I think I hear differences.
Your assessment of amplifiers probably applies in 95% of system situations, but likely not in real hi-end applications where speaker impedences (and sensitivity) and the ability to really generate low bass puts demands on the amplifier that cheap designs are unlikely to satisfy.
I recently replaced the 3-channel Adcom amp in my HT with a model from Krell, and while the differences are not enormous, I do get a quite noticable improvement in the bass.
As the famous philosopher once said (OK, maybe not so famous since I cannot remember who): 'just because you say there is a difference does not meant there is, and just becasue you say there is no difference does not mean there isn't'. Or something like that
