Originally Posted by blackdeath231
I have a KV-32HS420 which started out with having the 7 blinks from the stanby light on the front. I replaced the 2 IC's on the D board and now I get 6 blinks.
I have done a lot of reading on this and I am thinking of changing out both the FETS q8014,q8013. I also am looking at replacement of the IC504 as the service manuals suggest could be one of the problems.
I have also located another SHINDENGEN MCZ3001D on the AY board which I will change first.
Any help or other suggestions would be much welcomed.
Before replacing those other components, I would double check all of your new soldering. You might want to re-flow every new solder joint and check carefully for damaged PCB trace material. If you're not sure, check for continuity with a multi-meter. Also, if you disconnected anything for the repair, disconnect and reconnect everything.
If that all checks out, I would recomend swapping the A-Board MCZ300D IC next. A Sony service technician once told me that the A-Board IC is often missed in failed repair attempts.
Good luck!
Bob
