DIY Custom Gray Tints For Behr Ultra Pure White Paint
Originally Posted by wbassett
For a Munsell N7 neutral, and again this comes straight from Xrite, not a guess, the tints and ratios required are:
Lamp Black 0 15 1
Brown Oxide 0 3 1
Medium Yellow 0 1 1
This is for a quart. As I mentioned I am checking with Xrite to see if they have a formal N8 and N9 ration that was also tested like the N7.
To achieve lighter shades of gray I have mixed this down with un-tinted Behr Ultra Pure White paint. The un-tinted UPW has an RGB of 248 248 241, therefore as you dilute the N7 tint it will move away from a neutral gray. In an effort to offset this I have rounded up for the Lamp Black and rounded down for the Brown Oxide and Medium Yellow.
I have acquired some Behr UPW #4850 tinted "Dark Gray" (ie 0 8 0 LB ...). This shade appears to be very close to an N8 shade. Given that observation, I have guesstimated the relationship to the Munsell gray scale. If and when I get actual spectrometer readings I will post them and update these tints if it is warranted.
Tint formulas reflect the new 384ths ounce colorant measurement for Behr Paints.
Xrite N7 Tint Formula {Ultra Dark Gray}
Quart Custom Tint
Behr UPW (1050,1750,1850,4850)
124 Lamp Black
028 Brown Oxide
012 Medium Yellow
Gallon Custom Tint
496 Lamp Black
112 Brown Oxide
048 Medium Yellow
~N7.5 DIY Tint {Extra Dark Gray}
Quart Custom Tint
093 Lamp Black
021 Brown Oxide
009 Medium Yellow
Gallon Custom Tint
372 Lamp Black
084 Brown Oxide
036 Medium Yellow
~N8 DIY Tint {Dark Gray}
Quart Custom Tint
Behr UPW (1050,1850,4850)
062 Lamp Black
014 Brown Oxide
006 Medium Yellow
Gallon Custom Tint
248 Lamp Black
056 Brown Oxide
024 Medium Yellow
~N8.5 DIY Tint {Medium Gray}
Quart Custom Tint
048 Lamp Black
011 Brown Oxide
005 Medium Yellow
Gallon Custom Tint
192 Lamp Black
043 Brown Oxide
019 Medium Yellow
~N9 DIY Tint {Light Gray}
Quart Custom Tint
031 Lamp Black
007 Brown Oxide
003 Yellow Oxide
Gallon Custom Tint
124 Lamp Black
028 Brown Oxide
012 Medium Yellow
Updated: 2009-08-18
NOTE: I have had the same tint formulas mixed in all three Behr bases, #1050, #1850, and #4850. Under room lighting, light from the projector, and bright sun light I have not been able to detect any significant difference. There may well be a measurable difference with a spectrometer though.Very Loose Gray Scale Selection GuideWhite Screen - Untinted Behr UPW (1050,1850,4850)
This is probably the easiest screen shade to specify the conditions for. A darkened room with no ambient light, dark colored ceiling, and dark colored walls. This would obviously be a dedicated theater room. A typical light colored living room with vertical blinds and all the lights turned off does not qualify. If you do in fact have a room that is suitable for a white screen then you should probably reconsider the
Wilsonart "Designer White" laminate as the best white DIY screen surface.
Light Gray - ~N9 Tinted Behr UPW (1050,1850,4850)
This can be a good selection for a dedicated theater as well. If your projector has weak blacks, there will be some low level ambient light, or your room colors are not really dark, a light gray can be beneficial. You may actually find that when the room is fully darkened the light gray is almost identical to a white screen.
Medium Gray - ~N8.5 Tinted Behr UPW (1050,1850,4850)
This is really just a compromise shade for those unsure if they want a light gray or a dark gray. It may also be a good choice if your projector has a video optimized output of less than 400 Lumens and/or your screen is larger than 100" 16:9. If you will be using your screen in a light colored living room but plan on turning all the lights off and completely block any windows this may also be a good choice.
Dark Gray - ~N8 Tinted Behr UPW (1050,1850,4850)
This is the shade of gray that will tolerate fairly high ambient light conditions while still allowing a home theater projector in the 400 lumen range light up a 100" 16:9 screen. For example, a living room with light colored surfaces, and enough undirected light on to read and/or eat dinner.
Extra Dark Gray - ~N7.5 Tinted Behr UPW (1050,1850,4850)
This would be a good shade for a screen in a public area where a fairly bright presentation projector is being used. A small conference room with a presentation projector in the 2000 lumen range. This is probably not a good shade for a home theater projector. This would be a good shade for a softly lit pub with a projector like the Optoma EP1690 which was measure to put out over 1000 lumens when fined tuned for a high-contrast image.
Ultra Dark Gray - Xrite N7 Tinted Behr UPW (1050,1850,4850)
If you have a veritable light cannon and need to use it in fairly bright ambient light conditions, then this would be the shade to consider. This might be a good shade for a well lit restaurant and a projector like the Sanyo PLV-WF10 projector. At 4000 measured lumens with both lamps on and half that with one lamp on it will be able to light up a very dark gray screen.
Spreadsheet calculations for the Behr DIY Gray tints.
XriteN7_Behr_Tint_Calcs.zip 3.5703125k . file
