I've had a AE2000U for a few years now (great projector!), but tonight it started shutting itself off after just a few minutes of use. The lamp is at 2468 hours, and the "replace lamp" indicator has been on for a while now, so I guess it's trying to tell me something.
The thing is, before it shuts down, the picture quality is beautiful and bright -- same as the day I bought it. Is the lamp simply shutting off because the lamp hours counter is reaching some preset limit, or is the unit sensing a bad lamp somehow and proactively shutting it down?
Also, if anyone can recommend a good source for a replacement, I'd appreciate it (I can probably install it myself unless special tools are needed).
