Originally Posted by
sid*
just got a used ae2000 off ebay... its my first projector... so to me its great!
but has 2015 total hours usage and still on its first bulb... is that heavy use?
Congratulations on your purchase. Enjoy! Mine's still going strong after four years and only two replacement bulbs.
The risk of a bulb blowing supposedly goes up as it ages, but I've never seen stats about how many catastrophically fail versus just going out. I replaced my first bulb after the recommend time period, but kept my second one through two resets -- more than 4000 hours. I agree with other poster, it is much more likely to get too dim over time than to fully fail. At 2000 hours, it's definitely worth the tiny risk to keep it going and save money IMHO.
sid*
the red lamp lights on... but starts up and runs ok without turning off
You can go into the service menu and reset the hours. That will keep the red light off and avoid a startup delay that happens at some number of hours (2500?). See the manual for how to do it, I don't have the manual with me.
