AVS › AVS Forum › Blu-ray & HD DVD › Dual Format Players › LG BH100 will NOT play list
LG BH100 will NOT play list - Page 6
post #151 of 238
There is a new update on the way
Athanasios
post #152 of 238
Athanasios
When and according to who? The last update didn't fix crap.
post #153 of 238
Athanasios
post #154 of 238
Funny!
post #155 of 238
It fixed Band of Brothers.
post #156 of 238
I have been in e-mail contact with someone at LG( not Privy to divulge info)
and told them about the X-files problem even after the latest update. they then responded that they confirmed it does not play and are working on it and about a half dozen other movies, along with some other bugs ( not sure what those are). the are suppose to inform me when the update is out, this e-mail was a couple weeks ago.
Don't ask me for more info because this is all I know.
Athanasios
post #157 of 238
...and told them about the X-files problem even after the latest update. they then responded that they confirmed it does not play and are working on it and about a half dozen other movies, along with some other bugs ( not sure what those are). ....
Athanasios
It is very perplexing that LG can not get these problems fixed ONCE and for all. I would think that the Blu-ray speck is some what stable now. Other manufacture are not having the same problems. So why do all these problems persist with the LG bh100?
post #158 of 238
Disney's "Bolt"
This is before the installation of the 090121 kernal update. We'll see if this update fixes the issue.
post #159 of 238
Originally Posted by brettcam View Post
Disney's "Bolt"
I watched Bolt last week and it worked just fine on the BH100 with the 01/21/09 update.
post #160 of 238
Anybody else having a problem with "Swing Vote". It would not play past the Loading screen.....
post #161 of 238
Swing Vote didn't work with the previous firmware, don't know about the latest one.
post #162 of 238
I just received a firmware update disc dated 2 9 09
but when I put it in my player it says it's from January. ugg
post #163 of 238
So far that is the most current update.
post #164 of 238
Hi
Pardon my total ignorance on the access to and installation of whatever is the latest update for the BH100.
Mainly, I want to investigate HDDVD rather than BluRay - a long story
another post says " I watched Bolt last week and it worked just fine on the BH100 with the 01/21/09 update."
I presume this update adds in all updates HDDVD and BluRay
You seem to be the expert tho :-)
I have read all I can - visited the LG site etc etc. but cannot locate anything
I use a Mac computer (OSX) and don't have any access to a Window machine
Can you assist with a set of instructions to help me do this upgrade
a set of links would suffice - I think
best regards
Russell Naughton
PO Box 281
Nunawading
Victoria
Australia 3131
post #165 of 238
Originally Posted by Rusty Bottom View Post
Hi
best regards
Russell Naughton
PO Box 281
Nunawading
Victoria
Australia 3131
Others in this thread have contacted LG support and have received a Update DVD in the mail.
post #166 of 238
French Connection
post #167 of 238
French Connection
Sorry, i did not get post one update back in march. Post one now lists French Connection.
post #168 of 238
Just purchased Horton Hears a Who Bluary> It states player needs firmware update to play disk.
Does anyone know what DVD burning software will work properly with the ISO file.
My firmware version must be pre-2009 so I assume the latest firmware zipfile available @ 2009 will make more BD work properly in the player if I update to it?
Has anyone had success updating thier LG BH100 Player with the 2009 file?
post #169 of 238
Horton Hears a Who will play on the BH100 with the 1/2009 update. To find an ISO burner just do a Google search their are several free ones. Active@ISO is one that is free. Or I think the Beta Window 7 has a built in ISO burner.
post #170 of 238
Imgburn is the best and it's free.
post #171 of 238
Ok thanks. I will try those. I'm still using Windows ME though. But will have to eventually switch OS.
It's good to know that the latest update will make that Bluray work though.
post #172 of 238
There are still some Disks that will NOT play on the BH100, even with the latest software.
post #173 of 238
"My Best Friend's Girl" will not play
post #174 of 238
"Drop it like it's hot."
post #175 of 238
I have been looking, but the unit i like is another LG unit. Very hard to buy another LG player. The Sony would be nice but it dose NOT stream Netflix content.
post #176 of 238
If you can fork out a little more, the Oppo's a gem (but also doesn't stream Netflix...didn't realize you had that requirement). Unfortunately, only LG/Samsung have Netflix-capable players at the moment...though Panasonic may have one due soon.
post #177 of 238
I did not know that the Oppo was avaiable outside of there beta program. Is it in full production yet?
post #178 of 238
My problem and concern is with the analog audio outputs and the lack of audio delay circuit in the BH100!! Anybody out there experiencing extreme audio issues? I have a Denon AVR3803 where they handle analog-audio only with no processing, the HDMI goes direct to the display projector in 1080p. The HDMI does NOT output the audio Dolby HD or the DTS True HD anyways. Any of these firmware updates revising the audio menu, or the lack of the True HD audio thru HDMI to anyone's knowledge?? Thanks to all!
post #179 of 238
I have come to the end of the BH-100 rope, almost two years of problems. This generation one player is too unreliable and has too many problems. I'am tired of not being able to play BR disks when friends come over. An then waiting up to 6 months for an update.
It is TIME to move on. I will be purchasing ether the Oppo or Sony BDP-s560. I can not justify buying another LG BR player just to get a Netflix streamer.
post #180 of 238
I just called LG about a BH100 update and they said they are releasing a new version of software for the BH100 on July 17 or 18.
  Back to Forum: Dual Format Players
