help me build a tv stand!
post #1 of 16
ok so i needa fill in the hole in my wall.. it needs to have 4 shelves or cubbys for my equip and a shelf for my center ch... then ill be putting the tv on top of that.. ti gotta cut all the wood just right for the hole its 45" wide and 80" tall im going to use speaker cloth to cover up the top above the tv and designs i would thank you!
post #2 of 16
If you can afford it, I would suggest you get a professional to help you!
post #3 of 16
lol why when i can do it all myself? im just looking for some designs/suggestions...
post #4 of 16
Cool... make sure you post pictures so we can see your handywork!
post #5 of 16
no doubt..
post #6 of 16
I'm assuming the hole is a cubby with sides and a back wall, if not never mind........
Make the shelves with a double layer of 3/4 "good one side" furniture plywood with a 1x2 of matching wood on the front edge.
Cut the bottom piece of plywood 13/16 shorter on the two ends and the back. Attach 3/4 x 3/4 cleats on the side and back walls of the cubby hole hitting the studs. Lower the shelf onto the cleats.
what it will look like is "floating shelves"
post a pic of the wall and we will make other suggestions.
post #7 of 16
http://www.avsforum.com/avs-vb/showthread.php?t=900827
is this speaker cloth? how would i do this just build a frame and stretch and staple it to the wall?
http://www.avsforum.com/avs-vb/showp...&postcount=176
post #8 of 16
Pretty sure it's black GOM (guilford of Maine) fabric. It is an acoustically transparent polyester fabric (see fabricmate.com to buy)
yes just build a sturdy frame and stretch and staple fabric. Position the staples where they won't be seen. Be sure to paint the frames black before attaching the fabric.
some pics in this thread of some frames.
http://www.avsforum.com/avs-vb/showt...ght=minimalist
post #9 of 16
http://i34.photobucket.com/albums/d1...ts00/stand.jpg
i want it 33" tall i did the sketch wrong...lowes said it would cost 150?
post #10 of 16
Looks like 3-4 sheets of furniture grade plywood if you do double thickness plus all the trim wood.
Yes $150.
You could probably get it done for $50 if you used single thickness (only 2 sheets), the cheapest grade plywood, no edging and you painted it black and didn't care how it looked.
For $100 (assuming you have all the tools) you should be able to come up with a paint grade, sturdy, good looking unit
post #11 of 16
This sounds like a job for a Flexi-Rack!!! Easy to build and you can finish it however you like.
See my lil flexi stand In this thread.
post #12 of 16
that wont b flush with my wall though... i saw this im liking also.
post #13 of 16
OK, just get this:
http://www.sauder.com/furniture/product.asp?p=82
Assemble and just slide it back into that space. I think it will just fit
post #14 of 16
Avg. Retail Price: $375.99 (more details) lmao!
post #15 of 16
post #16 of 16
lol i want a cheap tv stand for my bedroom not a 300k theatre.. just lookin for some suggestions of what oters have built..
