AVS › AVS Forum › Audio › 2 Channel Audio › Need help picking 2 channel Amp Receiver
post #1 of 3
I've a Yamaha RX-V2300 which does 6.1 channel processing for my main room. I'm trying to use its ZONE-2 for the outdoor deck speakers; however it takes away the Amp for the rear channels (in 6.1) from the main room.
Thus, I'm looking for a simple 2 channel audio amplifier to assist the ZONE-2 connections for my outdoor deck speakers. Nothing fancy, simple 2 channel audio amplification (hopefully cheap).
Any suggestions and help will be greatly appreciated.
post #2 of 3
check out Emotiva.com they make a really good affordable amp and give a five year warranty. C/S has been outstanding.
post #3 of 3
I'm not sure if THIS is the amp you are recommending or not, but it would be a good inexpensive soution.
