AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official PS3 FAQ Master Thread
Official PS3 FAQ Master Thread - Page 102
post #3031 of 4476
Originally Posted by drhankz View Post
Don't forget pressing DISPLAY on your PS3 will SHOW what the PS3 is decoding
Yeah, I know, but "Dolby True HD" / "DTS MA" also shows up on my bro-in-laws TV, and he doesn't have his PS3 hooked up w/ HDMI and doesn't have an HD AVR.
post #3032 of 4476
In theory there shouldnt be any difference in sound quality but the simple fact is there has not been any blind testing with the PS3 yet to tell either way.
post #3033 of 4476
Spoken by Mr. Analog "Ye of little faith"
post #3034 of 4476
Faith is for those that lack proof...
post #3035 of 4476
It's not easy to prove a negative.
Brandon
post #3036 of 4476
For those looking for a new PS3 Slim, I just picked one up at Best Buy. Looked like they just got them in stock today.
post #3037 of 4476
OH BOY - I'll have to run out to my BEST BUY and hope they
have (3) Slims to replace my (3) Fat Ones.
I never knew it would be this easy to loose so much WEIGHT
post #3038 of 4476
The PS3 Slims are also now shipping from Amazon, including free shipping.
post #3039 of 4476
Amazon still says "In stock on August 28th". I had a ton of Best Buy gift cards I wanted to get rid of otherwise I would have waited for Amazon.
post #3040 of 4476
This has been discussed at length on AVS and other forums. The bottom line is that it really comes done to the capabilities of the AVR. If the AVR buffers and re-clocks the incoming LPCM data stream then applies identical processing to what it applies post-decoding for the bitstream input then they should sound identical. For some of the betters AVRs this appears to be the case. However, most lower cost AVRs (and even some more expensive models) do not do the buffering/re-clocking of the incoming LPCM (in order to keep costs down) and some do not apply identical post-decoding processing. In this latter case its really the fault of the AVR when an LPCM input produces an inferior sound quality as compared to a bitstream input.
post #3041 of 4476
Not sure if its ok to post this but I will anyway...
I just purchased the PS3 slim on the Sony Style webpage for $199. If you apply for the Sony Visa card and IF you get instant approval you'll get a $100 dollar credit on your first purchase $299 and up. Your are immediately supplied the credit card # and security code to make the purchase.
heres the link:
http://www.sonystyle.com/webapp/wcs/...52921644595898
post #3042 of 4476
heres the link:
YA BABY - that is the way I BOUGHT my (3) FAT PS3s
I'm surprised they have the same deal on the SLIMs
post #3043 of 4476
Why do you feel the need to ridicule people buying a new product?
post #3044 of 4476
I'm not ridiculing people.
I have been an early adopter of way too many products and technology.
I'm ridiculing SONY for calling this new product a SLIM.
At lest call it something more logical like PS3 v2 or something like that.
I OBJECT to the SLIM name. Not the people buying it.
post #3045 of 4476
heres the link:
it said its reviewing my thing first... sucks
post #3046 of 4476
Yeah..my credit isn't stellar...I didn't get the instant approval either..I applied again using my wifes info and got the approval.
post #3047 of 4476
This is a joke, right? So I suppose you also object to EXTRA STRENGTH Tylenol because you think that makes regular Tylenol UNDERDOSED? And you must also get hot under the collar by DIET Coke because you think that implies people who drink regular Coke are drinking Coke FAT?
The name PS3 Slim does not make or imply the old PS3 is the "PS3 Fat" except in your mind. The PS3 is still the PS3, period. The fact that you think the name PS3 Slim casts a negative implication on the PS3 is your issue, not Sony's, and I doubt it is shared by many people. I far prefer the name PS3 Slim, which is cute and catchy, to your cold and robotic "PS3 v2," a moniker that only a bureaucrat could love.
post #3048 of 4476
I don't think Sony is calling it that as they just said it is slimmer. It is the media and public giving it that label and you, you, you, its all your fault
http://blog.us.playstation.com/2009/...september-1st/
https://www.sonystyle.com/webapp/wcs....com/index.php
post #3049 of 4476
If dolby digital or DTS on a sd-dvd is sent out LPCM via HDMI so its LPCM 5.1 is that then uncompressed or what is it?
post #3050 of 4476
PCM is not a compressed format. However what you are referring to is compressed audio data decoded to uncompressed PCM. The decoded audio is not improved just because it is now in uncompressed form.
post #3051 of 4476
I've updated Post #2 of this thread (i.e., the PS3 FAQ) to add a link to the new PS3 Slim thread, to clearly indicate this FAQ thread applies to both the full size and the new PS3 Slim models, and a few other minor corrections (typos).
post #3052 of 4476
post #3053 of 4476
Just installed Firmware 3.00
Looking forward to seeing if their are any changes to our current settings. I haven't looked over the changes yet but I thought I heard something about a new audio feature or something?
post #3054 of 4476
You're probably referring to the fact that you can output audio via HDMI & optical simultaneously now.
Brandon
post #3055 of 4476
Brandon
How would this benefit someone? (sorry for the dumb question)
post #3056 of 4476
well for instance if someone has a second set in another room they want to play the video on at the same time. You can output Component/Optical and still get HD vid and 5.1 audio on that set too. Or if you have optical headphones (like the Astro A40's) you can output HDMI to your AVR/TV while at the same time running the optical out to your headphones.
post #3057 of 4476
HDMI + Optical, you could feed HDMI to the AVR and optical direct to the TV, for use by people in your household who just want to watch the disc without messing with surround sound.
HDMI + Analog, you could feed Zone 2 on the many AVRs that have this feature, nearly all of which require the Zone 2 source to be analog. Useful when using the PS3 as a music server.
Not clear to me is whether the PS3 is feeding multichannel audio via HDMI while simultaneously downmixing to 2-channel for analog.
post #3058 of 4476
Except there's no indication that it now supports simultaneous video output. Only audio. I would be hugely grateful if video was simultaneous analog/HDMI video was now supported.
post #3059 of 4476
I've updated Post #2, the PS3 FAQ, to indicate firmware 3.00 is now available for automatic download/installation and also that there is now a option under "sound settings" for "audio multi-output". Currently the ver. 3.00 firmware is available for download and automatic installation on internet connected PS3s, but not yet available for download to a PC for manual installation. The file for manual download is typically posted to the web a day or two after it becomes available for internet connected PS3s.
post #3060 of 4476
Which is still so unfortunate...
