The problem is that the music sounds worse at 48Khz. I solved the issue by moving the files to the PS3 hard drive, but I hope eventually a fix will be put in that I can go back to streaming.
post #3091 of 4164
9/10/09 at 8:16pm
Prior to 3.0, the only way to get 44.1KHz playback on the PS3 was to play the actual cd. I'm not sure what the sample rate of purchased and downloaded mp3's and iTunes are. I tested the streaming of my 44.1KHz wav. files. Everybody here is right. They now skip like crazy. My Denon AVR says they are sampled at 44.1KHz though, which is great if they can fix the instability.
