AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official PS3 FAQ Master Thread
Official PS3 FAQ Master Thread - Page 122
post #3631 of 4149
Originally Posted by Wryker View Post
I was thinking I was 'future-proof'.
I think it's painfully clear that there's no such thing in this industry.
post #3632 of 4149
Yep, when it comes to technology there is no such thing as future proof.
post #3633 of 4149
Originally Posted by drhankz View Post
Think about how OLD some of these PS3s are - with HDMI 1.0
I find it hard to believe Sony can get any 3D to work.
All the PS3's (even the originals) came with HDMI 1.3.
post #3634 of 4149
If that was true they could bitstream which they can not do until the Slim which got HDMI 1.3
post #3635 of 4149
Slims are 1.3a and Fatties are 1.3. Or something like that.
Brandon
post #3636 of 4149
It was the chipset that they changed - the original chipset did not have enough bandwidth. But the original PS3 always had 1.3 HDMI.
post #3637 of 4149
I have music set upon my Windows Media Player and have always been able to stream music to my PS3 without any problems. This afternoon I tried streaming music, but it kept on having frequent audio breaks. I tried a blue-ray to make sure it wasn't my HDMI cable and there were no audio breaks encountered so it is not my cable. When I play the files on my pc, they play ok. This is just a recent occurence as I have not experienced this in the past 2 yrs and to my knowledge, no changes have been made. Anyone have any thoughts?
post #3638 of 4149
Is it possible to get HD audio from the PS3 to AVR in 3d by using an optical cable?
post #3639 of 4149
No. But if you have both the HDMI and optical cables connected to your AVR whatever audio format you select for your BDs will play through the HDMI (HD audio, PCM, etc) and for 3D BD's it will 'automatically' use the optical audio since no 3D BDs will output HD audio on the PS3 - they're all downmixed to DTS/DD.
post #3640 of 4149
It is not possible to get multichannel HD audio using an optical cable under any circumstances, regardless of the player or the number of dimensions of the video.
HD (lossless) audio on a PS3 requires HDMI.
post #3641 of 4149
I'm having fun making slideshows of various family vacations etc, but am wondering what settings would be best for the PS3 and my TV. I have a Mits 65" DLP 1080p. I've been trying various settings and it seems that 3840x2040 pixels works well, but I'm not sure the files need to be so big.
Just wondering what other people might have found.
post #3642 of 4149
So is there any reason to use the optical cable, or should I just keep things simple and only connect the HDMI cable?
post #3643 of 4149
It's good to keep the files big, then you can zoom into them with the PS3 and see more detail.
post #3644 of 4149
True, but if my TV can only display 1920x1080 is there any reason to have 3840x2570?
post #3645 of 4149
Yes, zooming in, the pic will look better if it is higher res, regardless of your display resolution.
post #3646 of 4149
Good to know. I notice that my RAW photos show up fine on the PS3 using PS3 media server. I'll do an experiment and see if they look any better than the Jpgs at full resolution.
post #3647 of 4149
HDMI is fine as long as you don't plan on watching any 3D Blu-Rays.
post #3648 of 4149
I do plan on watching 3d blue rays. What purpose will the toslink cable serve if it can't pass HD audio?
post #3649 of 4149
Toslink never could pass HD audio only Dolby and DTS.
post #3650 of 4149
Or even if you are. You will get the same "core" audio -- lossy DTS or DD up to 5.1 channels -- with either HDMI or optical from a PS3, even if the soundtrack on the disc is DTS MA or Dolby TrueHD.
The only reason to use an optical cable is if your AVR woun't pass the 3D video to your TV, and so you have to connect the HDMI cable directly to the TV. Then you'd use optical for audio, and connect it to the AVR.
post #3651 of 4149
can someone help me...
i have a g25 viera and my ps3 just start to make some little white rambom spot when i try 1080p for game but as soon i turn it to 1080i the ''spot'' diseapear . oh and every thing is ok in 1080p for blu-ray..
any answer for me.
thanks.
ps:I use a hdmi cable.
post #3652 of 4149
Actually, TOSLink can pass two-channel PCM.
post #3653 of 4149
Correct, but I was assuming multichannel sound, and also I have my doubts with 3D if it would be putting out even two channel PCM.
post #3654 of 4149
Hi, I really hope anyone can help me...
If I play a 3d Bluray on my PS3 I have an excellent image on my Panasonic VT20 but NO sound at all. The PS3 is connected to a Marantz receiver (hmdi 1.3) via HDMI. I've tried all settings I think.
The strange thing is that when I play downloaded 3d blurays via my mediaplayer both picture and sound works fine.
Is it perhaps that a 1.3 receiver can't process both 3d picture and (any) sound?
Can anyone please help?
Thx!
post #3655 of 4149
Thx!
What are you trying to watch via BD? As already posted the PS3 can not pass HD audio so if you're trying to watch it with HD audio it won't work. I suggest either trying to "dumb down" the audio or connect an optical cable and config that .
post #3656 of 4149
Thx!
That's been stated many times before.
post #3657 of 4149
Maybe a stupid question.
I just upgraded to the latest firmware on my PS3. Is there any setting that should be changed with this?
post #3658 of 4149
Dankfoot -- I didn't make any changes to my 40Gb PS3 after I installed version 3.5 of the firmware. Everything seems to still be working as it did before. Despite the problems many posters had with various versions of the PS3 firmware, I didn't have a problem with any of them.
post #3659 of 4149
Thanks gwsat
post #3660 of 4149
Thx!
Even if you have one of the few HDMI 1.3 AVRs that can pass-thru the 3D video from the PS3 (in Frame Packing signal format), the AVR will not be able to extract the audio since the Frame Packing format does not have the audio in the same place within the HDMI signal format as used with earlier versions of HDMI. You need to connect an optical audio cable (i.e., Toslink) from the PS3 to your AVR and go into the PS3 settings to change the digital audio output to optical (instead of HDMI). Also on your AVR will will need to set the audio input to the specific optical input you have used to connect to the PS3. Downloaded 3D videos are not really Blu-rays as they have been altered in order to reduce the file size (40+ GB for a true Blu-ray 3D movie) and downloads are are not using the full 1080p resolution HDMI 1.4a frame packing format used by true Blu-ray 3D discs (i.e., downloads don't provide the video quality of an actual Blu-ray 3D).
