PM sent.
post #2551 of 3265
7/27/11 at 4:22am
Hi guys,
I have these doubts: 1 - With the points above, how would a 1.4 BD III perform? And how it woud compare with a good 0.9 gain HC gray screen? 2 - What is the best placement of screen/projector/eyes to optimize gain? 3 - Is there another screen that would perform better and could be shipped to Brazil? Thx |
Could you do the same with the viewing angle. I know the 2.7 will have the narrowest bc of the gain, but ive read where its still good.
Are all of these retroreflective? |
Will Edit In..
Now Done... Repeat... Here is how I class the BD Gain's .8 Best Blacks , minor sparkle Viewing Angle 44% 1.4 Very Good Blacks and More Contrast, Minor sparkle but little more vs .8...Viewing Angle 55% 2.7 Okay Blacks and Alot of contrast, little more sparkle vs the 1.4..best 3d..Viewing Angle 60-65% Again when it comes to my screens of Choice, My First Choice is always an SI Screen Love there company and there staff including there RnD DEpt is amazing.. FYI, They Do have other screens in the Line up List of there Reference Screens including BD... http://www.screeninnovations.com/pro...xed/reference/ |
I'm curious if any of you have compared the BD's to the new Dalite HiPower 2.4 gain screen. I imagine the BD's have better light rejection, but that the HP's are free of any artifacts, i.e., sparkles, etc. Would be interesting to hear about any direct comparisons.
Unfortunately, I cant. My local dealer only has a gen2 0.8 gain. Hes way overpriced, livesvin an expensive neighborhood and can charge that. He knows I basically was using him to look at a sample. Im in Birmingham, AL so we dont have much. Id be willing to drive to Atlanta, or Nashville, if I knew of one there.
HP vs BD are two different animals. The HP is retroreflective which reflects light back towards the projector, a good choice if your head is near the projector like mounted just above head height. The BD is angular reflective which reflects light at the same angle away from the light source, similar to a laser pointer hitting a mirror. Tends to work best for ceiling mounted projectors.
Tends to work best for ceiling mounted or is recommended? What would be the optimal projector placement on an angular reflective screen like BD 1.4?
i'm thinking about using a 2.40 aspect screen in a 130"ish screen. My concern is the viewing angle... with a wide screen like this and with the black diamond, will colors/brightness fall off noticeably at the sides of the screen? should i stick with a 16x9 screen for uniformity?
