Kdh,
From what I understand the bd will help a lot. There is a video on YouTube where they compared a normal white screen to a bd. the white screen lit up the room. The reflections from the walls and ceiling washed out the screen. They then showed the bd and that room stayed dark and the image looked great.
Have you thought about painting the room a darker color, if you could paint the ceiling as well that may solve your problem. Go with a dark flat paint.
