AVS › AVS Forum › Display Devices › Screens › Black Diamond from Screen Innovations?
Black Diamond from Screen Innovations? - Page 119
post #3541 of 3545
Originally Posted by space2001 View Post
There website says up to 200" but when I try to do the screen calculator it only goes to 120.
I have a 120" Da-lite Cinema 1.1 now. My whole thought is go bigger later this year. Trying to find which screen to go for and I like the idea even though I have a light controlled room my walls are not dark.
115" 16:9 regular and 120" 16:9 Zero Edge are the largest available. You can go to a scope screen and get a larger scope image and the same size 16:9 screen. If we can help you, let us know.
post #3542 of 3545
How's the acoustic transparency of the Black Diamond?
Has anyone tried placing a center speaker behind the screen?
How much is the high frequency roll off?
post #3543 of 3545
BD is not recommended as an AT screen material.
post #3544 of 3545
Finally getting my small theater room built out after waiting 8 months and am trying to figure out if I can use the BD or slate screen. Are there restrictions on the angle of the projector to the SI screens? I am looking at a ~110" 16:9 screen with the front of the projector lens approx 13' back. The ceiling is 8'10" but the projector needs to be close to the ceiling so somebody can walk underneath the projector.
post #3545 of 3545
Originally Posted by BlakeSI View Post
There is no need to mask a Black Diamond. The materials are self masking. Check out the video for the Zero Edge and you will see a 2:35 screen, back-lit with 16:9 content and I am sure you will deduce there is not need to mask.
Even though this may be true, are there any masking systems for the Black Diamond Zero Edge? Something perhaps that one could hang on the left and right to mask the black bars while watching 16:9 content on a 2.35:1 screen?
  Back to Forum: Screens
