AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › Projector Central Panasonic PT-AE2000U Review is Up!
Projector Central Panasonic PT-AE2000U Review is Up! - Page 3
post #61 of 65
I've almost decided to go gray because for movies a think the 350 to 400 lumens panny provides on best modes are enough to illuminate a 84" screen using min throw distance(1,85 to 1,90x zoom). I'm just a little bit worried about the gray whites you mentioned.
For viewing with some ambient light i believe the normal mode has plenty enough light too(900 lumens).
Do you agree?
post #62 of 65
Don't worry too much about the whites. I've used a gray screen for almost 5 years now and whites have never bothered me. Now, if you hold up a white screen next to it, then yes, the whites look worse on mine, but without the direct side by side comparison, you'll never notice it.
post #63 of 65
Yep, and on the other hand if you hold up a white screen next to yours the blacks will look better on your screen.
post #64 of 65
Will the 2000 be able to pump out at 1080p through vga??
post #65 of 65
Fixed pixel displays, display at their native resolution so they will take whatever you feed it and map it to the panel rez - in this case 1920 x 1080.
A good display should be able to 1:1 pixel map, that is if you feed it a source at its native rez it should display all those pixels without scaling.
So the question is your vidcard up to snuff?
ted
