AVS › AVS Forum › Audio › Receivers, Amps, and Processors › need a receiver for headphones only
post #1 of 6
I need a receiver that i will be using with my sennheiser hd555 and hd595 headphones. I plan to use the optical out from my pc, so SPDIF is a must (HDmovies will be 2 channel PCM anyway). I don't plan on hooking it up to any speakers either if that helps. I am looking for the best bang for my buck here. Thanks
post #2 of 6
You should look for a headphone amp with a digital input, HERE.
What is your budget?
post #3 of 6
looking at about 120 bucks i got one from sony
post #4 of 6
If you just need something to decode a digital source for a headphone, one of these will do
JVC SUDH1
http://www.jvc.com/press/index.jsp?item=501&pageID=1
post #5 of 6
I'm looking to spend no more than $150 USD.
post #6 of 6
Panasonic SA-XR55 @ $169.88 would be a small, lightweight (10lbs) solution.
SA-XR55 brochure
