AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Sony XBR4 or Panny 700u?
post #1 of 9
okay so im going to take the HDTV plunge very, very shortly
and im posting this in both sections (plasma and lcd) to attempt to balance people out slightly
now im not going solely on what feedback i get, but just curious to here your guys thoughts, and thoughts from people who own those tvs (ive read up a lot in both their respective threads, just looking for some comparative insight)
thanks ahead of time
post #2 of 9
I like the Samsung 5084 better then the panny. I would take the XBR4 over the panny. Both LCD and Plasma are good it really depends on the enviorment you will watch it in and your intended use. I have a 46XBR4 but i also really like the PQ of a plasma.
post #3 of 9
well itll be split between controlled lighting (for the time being), then likely a decent amount of lighting exposure, and SD cable, HD Cable, Blu-Ray and gaming...pretty multipurpose (how my tv will be used and the situations it will be sitting in) if you ask me..
post #4 of 9
The advantages for the XBR4 are the styling and matte (better at handling glare) screen. The picture's pretty good, too.
post #5 of 9
oh also ill be watching a lot of sports, and more specifically hockey just so you guys know
post #6 of 9
Panasonic for sports. The LCD's have pixilation issues in fast moving sports. Plasma has a faster response time and does not have that problem. Plus, Plasma has better contrast and deeper colors. I would go Panasonic all the way. It is one of the best you can buy!
post #7 of 9
Further info to support doogiehowser (from \\/\\/ \\/\\/ \\/\\/ .hdguru.com/will-the-2007-hdtv-you-choose-give-you-all-resolution-you-expect/187/ and also the reason why I have chosen PDP (Panny TH50PF10UK) over LCD (Sony/Samsung). I also will tend to watch more sports and use the panel more for TV viewing than my HTPC.
Static and Motion Resolution
A particular HDTV may resolve a stationary test signal at full bandwidth, but what happens when motion is introduced? The answer, the on-screen resolution drops. This can have a significant affect on your viewing experience, especially if you tastes tend toward sports and action. How much resolution loss occurs? To find out I used a new test tool called the FPD Benchmark Software for the Professional. This Blu-ray disc contains a pattern called a monoscope pattern (pictured above) which is made up of a series of four black lines drawn so they gradually come together in a wedge like pattern that appears at the top, bottom and sides. There are numbers adjacent to the lines indicating resolution. One section of the disc has the pattern stationary (static resolution), in the following section, the same monoscope pattern moves from left to right (motion resolution). The stationary number where all four lines could be distinguished was recorded and then the test was repeated with the motion pattern with the area where the four lines could still be discerned as separate and not blurred together was noted. These numbers were then compared.
The result, three distinct groups emerged from this test of the twenty 1080p displays. All displays in the top group were plasma HDTVs. They all had a static resolution of 1080 lines and a measured motion resolution of 830-880 lines, depending on the specific display. The next group consisted of microdisplay rear projectors, static measured 1050-1080 (depending on the display) while motion resolution ranged of 610-780 lines. The bottom group were all the LCD flat panels, with a static resolution of 400 (one panel) to 1080 lines and motion rez coming in at 360 lines (one set tested) to 600 lines. Three of the LCDs tested were 120 Hz models (one was the Sony KDL-46XBR4 reviewed here), all 120 Hz models had 600 lines of motion resolution.
Good luck in your purchase...
Dan
post #8 of 9
I'm confused... I just started researching since I'm looking to replace a broken DLP and I've read in a couple different posts about sets losing resolution with motion. Does this mean the TV is actually displaying fewer lines or just that fewer lines are perceived by the viewer? I don't understand how a 1080P LCD would actually display fewer lines than a 1080P plasma.
Dan
post #9 of 9
yeah i decided before you posted that that i believe im going with the panny, its cheaper, slightly bigger, and its biggest drawback is just weight/glass (and the glass isn't a giant issue, weight same)
the only thing i wish the panny had was more hdmi inputs (at least 3, not 2)...the pioneer is nice, but its more money and isnt even 1080p (though many would say that's not a huge deal, for the money im forking over id appreciate if it was 1080p, seems pioneer is as bad or worse than sony when it comes to pricing on products because while they picture may be a bit better, i dont think the difference between pioneer other good plasma brands is as big a difference as sony and other top lcd brands...i think sonys look much better than sammy and sharp)
anyone know where to get deals on plasma's (preferably panny's or even pioneer's?) i really could care less to pay retail at BB, Sears, etc
