Sorry to beat a dead horse on this (and I am not trying to offend anyone...just trying to get to the bottom of this), but I asked about RGB FULL at the Beyond3D forum (very knowledgeable folks there just like here) and was told that essentially if your display supports it, then turn it on. You think this guy is correct? Here is the conversation...
Originally Posted by pux
Originally Posted by michaeljamesjohnson
AVSForum members are convinced that the PS3 simply stretches the RGB Limited "16 to 235" color space to "0 to 255" when turning on RGB Full on both the display and the PS3. They claim the PS3 still sends a "16 to 235" signal no matter what. At least this is the way I understood it. I have several questions...
1. Do you think XMB and PS3 games use sRGB?
Yes.
The native format (or framebuffer format) for XMB and Game is sRGB.
And sRGB is identical with full-range RGB in PS3.
So you had better turn on "full-range RGB" if you have a receiver that also suppors full-range RGB, and you get lossless singnal.
The reason why limited-range RGB (that offers degraded signal) is default is that limited-range RGB is defined as default format in HDMI specification.
Even more full-range RGB is not valid format before HDMI1.3 (except DVI compatible output)
2. Do you think the XMB and PS3 game sources will really take advantage of RGB 0 to 15 and 236 to 255 when turning on RGB FULL? Maybe it is not a source thing, but instead the way the RSX renders and ouputs the color space?
XMB and Game always render in sRGB regardless of what range you choose.
HDMI Tx stretches to limited-range RGB if limited-range RGB is set.
3. Are there any RGB or YCbCr "Deep Color" sources yet and if so, how do you turn this feature ON/OFF in the PS3? This is a color depth feature, and I dont see any settings. My XBR4 supports 10bit color sources rather than just 8bit. The HDMI.org site advertises that this is a PS3 feature.
It is auto-configured if your receiver supports deep color.
There are few deep color source though, deep color & limited-range RGB provieds almost the same quality as 8bit full-range RGB.
The only REAL deep color source I Know is "Foldingf@Home".
4. Do any YCbCr sources (SD-DVD/Blu-Ray) take advantage of x.v.Color (aka xvYCC)? This is a color gamut setting that extends YCbCr from 16 to 235 to 0 to 255 kinda like the RGB LIMITED vs. FULL setting. My XBR4 and Onkyo receiver both have x.v.Color settings I can turn on. HDMI.org says that this is a PS3 feature.
It is auto-configured, if "Super White" is set and your receiver supports xv.Color.
But both DVD and BD have not support xv.Color yet.
AVCHD is only xv.Color source at present I suppose.
XMB and Game never send YCbCr, that means, neither send xv.Color.
Just for reference, the framebuffer format of BD/DVD Player is YCbCr, but
the one of XMB Media Player is full-range RGB.
One more thing, xv.Color extends gamut but color-range is still the same as the one of YCbCr, while full-range RGB extends color-range but gamut is the same as the one of limited-range RGB.
5. Is "Super White" the only PS3 x.v.Color setting? I cannot find any others. The setting only seems to help in calibration on Blu-Ray discs. It passes BTB 0 to 15 and WTW 236 to 255 info when calibrating. It does not seem to effect the actual movie itself.
Yes.
And because again, DVD and BD have not supported xv.Color yet though,
they usually contain Super White signal.
but unfortunately many LCD TVs can not handle Super White signal.
Try legacy CRT TV, or long for Organic EL
Sorry for my poor english.
Yes.
Yes.
