Originally Posted by samwise7
I came across a couple of products used to eliminate 50/60hz noise in AC lines and I was wondering if anyone thinks these may be used to perform the same function as the isolating transformer that was mentioned a couple a pages back. I figure I could try them and if they don't work, I can return them pretty easily.
http://www.ebtechaudio.com/humxinfo.pdf
or
http://www.audioprism.com/quiet_install.pdf
or
No dice, these are used to eliminate ground hum.. that's a low level hum coming from speakers... I use these in my PA system, they won't help you on banding...
. WOW this projector is just amazing. Best purchase I have made in years.
LOL Anyway, I look up at the screen and lo and behold........Horizontal Banding! DAMN!
Then I realize it was a scene in the movie that was depicting a TV broadcast and the "banding" was in the movie itself.
Being paranoid, I'd like to have a spare and if the OEM should go I'll be ready. Did that with my Mitz 73" DLP TV a year and a half ago and the original lamp is still going strong.
Anybody ever order anything from this place? Never heard of 'em.
