Originally Posted by 257roberts
Okay got the 8100 mounted and running. No banding that I can see. Very sharp and Cadillac controls and adjustments! Does someone have a set of calibration numbers that I could start at with a new bulb? I have downloaded the AVSHD disk and have it running. I also bought a set of blue, yellow and red filters you look through a while back, but have forgotten how you use them. The image now with just limited calibration looks kind of dull and the skin tones look too red. Blue seems too vivid also. Is it just me or do the menus of this projector seem confusing and hard to navigate? Thanks for your help and assistance! Anxious to get it somewhat adjusted and start watching movies again!
Your questions are exactly as most have had during the length of the thread .. the AVS search option is a good place to start .. and immediately set the menu timeout higher than the default .. see if you have PCS turned on as well ..
I seldom turn down the opportunity to talk Home Theaters with other enthusiasts, and it's the least I can offer for another local Pro8100 owner.
