AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Best way to connect HD-A3 player to MITS. 3000
post #1 of 4
[FONT="Comic Sans MS"]I read many post but not sure the best way to connect the video ( hdmi or componet) for best image. The second is the audio, I have pioneer thx 1015 avr no hdmi connection but optical. What type of sound can I expect??[/font]
post #2 of 4
Use HDMI for video it will allow you to upconvert SDDVDs. Should see a big difference with HDDVD.
"If you are using the optical output in bitstream mode you will only get Dolby Digital 5.1 at around 640kbs bit rate. In PCM mode it only has bandwidth to support 2 ch PCM". Originally Posted by Optica
post #3 of 4
HDMI for video and optical out from the HD-A3 for the audio. Unfortunately audio over optical on the HD-A3 isn't as good as the HD-A2, but it's not bad either.
post #4 of 4
Thank you this is what I thought
