Why dial down your ANSI intentionally? Killer ANSI in large part is a major benefit for going to C3X IMO and the ND is at best a short term solution as it will rob you of ANSI although your blacks and perceived contrast should be somewhat improved. Seems like Sim2 is showing quite a lot with the Firehawk G3 and Stewart is pushing this as a very good option with multichip DLP at this point as well. When both Stewart and the Sim engineers and marketing folks are hot on the FH you may want to consider that material also although it is higher gain. What are you shooting for in FtL Mark? Don't forget you'll have an iris to work with. BTW, does anyone know if the iris is separate or integrated as part of the bulb level adjustment setting?
post #211 of 2893
11/18/07 at 7:57pm
![Samsara [Blu-ray]](http://cdn.avsforum.com/0/09/50x50px-ZC-09d8536e_B008N9AAQ4-61ToEJTdd4L.jpeg)
I prefer my blacks to be nice and bright! What good are blacks on the screen if you can't see them?
