Thanks for asking about those solo ones as I had the same question but forgot to ask
Yes you should set the DD, DTS and all the upper ones to be the same and NOT use Last Valid or else you will get clicking noises sometimes
Not sure about the others though
Originally Posted by MRDC777
I have a question regarding the Listening Mode Presets in Menu 5-3.
Should these all be set so they are equal? For example, should DD be set to DD, DTS to DTS, etc. instead of the default Last Valid? If this is true, what should I set for Analog/PCM, D.F. 2ch, D.F. Mono, Multich PCM and 192k/176.4k as each of these do not have a corresponding option?
