Originally Posted by scarecrow420
so your problem is you dont want to have to manually turn on/off the GAME mode on TV when you switch inputs, and since everything runs through the receiver it si all going into the same input on the TV?
One solution might be to run the Dish video directly to the TV into HDMI input 2, with only the audio going to the receiver via optical/coax. Then your PS3 and X360 can go to the receiver first, then out from that to the TV into HDMI input #1. Then yo ucan have GAME mode on your TV input 1, and not on input 2. The PS3 audio is still going to the receiver via HDMI so you get the good audio for BluRay etc, and you arent "losing nything" witth the Dish tv audio since it would only be DD5.1 anyway which an SPDIF optical/coax can carry fine
Scarecrow thanks for the reply. I'm such a noob when it comes to this stuff. If I understand correctly I still wouldn't be able to take advantage of the TV's "game mode" because the TV won't see the PS3 or Xbox connected.
j/k
