The 705
Pat,
I started noticing a hum through my sub and fronts after changing my over-the-air TV antenna setup. Although the antenna is grounded, there must be a ground loop, a well-known source of 50-60 Hz hum.
I managed to isolate the source of the noise to the RF cable coming into my TV, which is connected to the 705 via HDMI. I eliminated the hum by installing a Jenson Ground Isolator (http://www.jensen-transformers.com/datashts/vrd1ff.pdf) available for ~$50 from numerous sources.
In your case, you would install the isolator between your incoming cable line and the cable receiver/DVR. If you want to read more about this issue, it's covered in the FAQ under "Why is there a loud hum in my sub?"
Hope this helps.
Originally Posted by Pbeaugrand
Hey there all
I just Bought a used 705 off craigslist mint condition from 250 to replace my aging HK DPR1001 and love it allot
only problem im having is a type of oddity in sound
also Im pretty skilled in HT so I did set it up right and using the RTA system as well
Great sound
When I hook up the receiver to my LCD ( samsung 650 series 46" )
and I use any source at all that plugged in and transmitting info
and I turn the volume past 75 On the right front and sub I get a hum
If I unplug the tv to hdmi on the receiver, HUM past 75 just on those 2 channels
I tried grounding and ungrounding the whole setup
Its only when I have any source such as DVD player via cox and cable box via Coax and cd player via rca when i hook the damn thing up to the tv via the receiver hdmi out I get that silly hum
Now when there is No info being passed on the digital ports like when I pause TV The hum is gone until It transmits data again
This is my first onkyo product and I want to love it but this issue is making me want to ebay it and save for a pioneer elite or something better..
Let me know what to do, I bought it used..otherwise, flawless
My setup is as follows:
Onkyo TX-SR705 receiver
2 Cambridge M80 fronts
1 Custom built Center
2 Cambridge M100 backs
1 JBL Venue 15 sub
1 Pioneer H400K 1080P upscaling dvd player via coax
1 Atlanta scientific 8240HD DVC DVR box ( time warner ) via coax
I have tried unplugging the cable box as well to make sure its not a cable ground issue
Its ONLY when I hook up the tv to the receiver or the other sources
so if Its DVR to TV via HDMI and DVR to 705 via coax I get hum and same if I run from the DVR to 705 to tv via HDMI loop through
same issue with dvd player
Let me know,
THANKS!
Pat
Hey there all
Great sound
1 JBL Venue 15 sub
Let me know,
THANKS!
Pat
Pat,
Hope this helps.
