Originally Posted by warlord260
i asked on the audessy thread, and no replies.
if i turn audessy off do i still get the timeing, and delays.
i would like to see the difference in subwoffer response between it on, and off.
it seems that when i use pure mode subs want to tear down the house. basiclly i am wondering if audessy is affecting subs response.
Yes, turing Audssey off in the equalizer menu will leave the timings and level cals in the other sections alone.
It sounds to me like you have your subwoofer turned up too loud. Look in the level cal menu and see what it has your subwoofer set at. If it gives you big negative number like -6 or -10 then you should turn down your sub volume knob down and redo Audssey. Using "Pure Audio" would disable this setting making the subowoofer louder. If you like a loud subwoofer, try turning the subwoofer in the level cal up to 0, and leave audssey on.
