Ok I'm a little confused about the differences between these HDMI Monster cables
According to the packages the faster ones are good for 1080p 12-bit color depth and 120hz frame rate.
I'm purchasing a 52 Sony XBR4 so according the Monster cable box I need to buy one of their new 1000 series because it supports 120hz 1080p+ etc.
So what is this I hear about speed? What is the correct speed I need ? Does speed matter when dealing with HDMI and 1080p signals?
I thought HDMI cables were just a series of data so what is the deal can someone break it down for me?
This is all very confusing and I did use the search option can someone break it down
I don't care what brand I buy but I saw Monster cables 600 800 and 1000 they actually broke it down on each box what they did so I'm just trying to figure this all out
thanks
thanks
