my trusty'n ole BD-30 now sports a 3.0 FW upgrade though...
What does 3.0 do? What does it fix? My principal concern is that loading the new FW will incapacitate the BD-30 that is working OK now. I had a similar occurrence with a BD-60 and could not go back to the old FW - the BD-60 had to be replaced by Panasonic under warranty with a BD-605 - which is the reason for me not to update any BR player (as long as it works) which is what Panasonic tech support suggested (if it ain't broke, then don't fix it, because FW updates may not be innocuous).
If you are worried, then don't update. Panasonic rarely gives us very specific details as to what the updates do.
I haven't downloaded this one yet but I seem to recall that when I downloaded previous updates, it had a txt file or something that provided a little more explanation.
I really don't know what the 3.0 FW fix, because it's not on paper, but I'm sure that if Panny is still working to release a new upgrade for an almost 4 years - discontinued BDP - there's gotta be something for the better, no doubt, but risks are always present, though
Unless they want to brick all the BD-30's so we all go out and buy the latest Panny can offer.
I did the upgrade with no issues. I didn't notice any difference with the new FW. I've only played a DVD through it. Haven't had a chance to try a BD or CD.
I upgraded to FW 3.0 yesterday without any problems from a Mac burnt CDR. Watched the BD of "Paul" last night and the player was flawless (funny movie, btw.) Got to give props to Panasonic for continuing to support their legacy products. I figured we had seen the last FW upgrade at 2.9.
Burned 2 discs and I'm getting an "e disc" error trying to update. I guess I'll download every burning program I can find until it goes.
Try downloading CDBurnerXP. It's free. Use the default settings and make sure you close the disc, no open sessions. Burning a CD with Windows Vista/7's built-in CD burning software has never worked for me for updating the Panasonic. CDBurnerXP works like a charm. What the new firmware does is anybody's guess. I wish Panasonic would release more detailed information. Good luck.
....... What the new firmware does is anybody's guess. I wish Panasonic would release more detailed information. Good luck.
Upgrades to firmware have come when a particular popular movie has trouble playing on a BD player. If the movie is to Blu-Ray standard then the player manufacturer responds to repair a bug.
Or, it may have nothing to do with watching Blu-Rays. Panasonic makes a lot of cameras and camcorders. Everything on the market now makes HD movies in "AVCHD". Unique to Panasonic is the ability to remove an SD card from a Panasonic camera or camcorder, stick it in the front slot on a Panasonic BD players and view. There is no need for wires, software or computers.
I have a very new Panasonic camcorder and was amazed to find I could do this with 2.9. I can't do it on a new Sony BD player. I'm guessing 3.0 would include something to do with assuring this feature continues to work with their latest cameras and camcorders.
^True. The BD30's are a good blu-ray player. The draw backs are, like you mentioned, no BD live (a feature I've never used on my other (PS3)), slower start up and standard dvd video performance (some jaggies). With blu-ray, high def content, they do very well.
I just upgraded my Panasonic BD30 firmware to 3.0, and it went without a hitch. I used a Mac for burning the disc and had no issues at all (I feel for the poor Windoze PC users that have to deal with making updates - it seems to be a major hassle for them). I played "Adjustment Bureau" and everything worked flawlessly so far. I did not try the Live feature because I am not connected to the internet (my TV system, that is). No bricking here!
Some of us are smart and some of us are not. Last but not least some us are also HUMBLE. I got Windows XPSP3 and I burned the FW upgrade, installed the 3.0 and I did NOT waste any blank CD-R's=smooth operation I am way far from being a computer genius
Thank you
