Originally Posted by davywavy
Using CDBurnerXP (with windows XP) I have now tried writing a data disc using iso9660 format at 4X burn speed. Again the same result.
I am trying to update from vers 1.7 to vers 2.7. Is there any fundamental reason this should not work? i.e should I attempt to update to 1.8 and then incrementally through the versions?
Has anyone successfully updated to Europe & UK vers 2.7? If so, could they explain what software they used.
Thanks for all your suggestions so far.
Almost hate to ask, but you're not trying to put Euro firmware in a US player or vice versa?
Doesn't do you any good...but for kicks I downloaded firmware for my BD65, burned the disk using XP's built in function as the Panasonic instructions show, and it worked straight away. The L FVU message came up but I just left it alone and it completed successfully first time. Point being, the process works.
