AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › The Official Panasonic DMP-BD30 Owner's Thread
The Official Panasonic DMP-BD30 Owner's Thread - Page 243
post #7261 of 12500
Originally Posted by jsmiddleton4 View Post
km....
U73 error....
Make sure the BD30 is the last thing turned on. This is not techincally an "error". The BD30 is not sensing any HDMI connection and the U73 is the code for that. The way you make sure you don't see the U73 message is by turning everything else in the chain on first, BD30 last.
Also double check your HDMI cables. I had some excessive "stress" on my cable for the BD30 (thick Series-1 Blue Jeans Cable) and it was causing intermittent connections which in turn cause the U73 error.
post #7262 of 12500
Originally Posted by ayrton View Post
The following link shows the specs of the BD30. Panasonic claims it will decode these formats. The only one it doesn't is DTS HD MA.
My BD10 does as well. I'm waiting for the 50.
Hope it helps.
http://www2.panasonic.com/consumer-e...00000000005702
Once and for all, the BD30 does not decode True-HD
post #7263 of 12500
Rynberg,
The Yamaha cost is $500.
The BD50 cost is ???
post #7264 of 12500
Hope it helps.
Perhaps "decode" isn't the proper word. The BD30 passes these signals (including dts HD MA) to a receiver via bitstream over HDMI, but the receiver must be capable of processing the signal or no advanced audio will be available. You will only get dts or DD. I think of what the receiver does as "decoding," but that may not be technically correct.
You will not get advanced audio from the BD30's analog outputs. (IIRC, your BD10 does this, except for HD MA.)
In any case, my answer to the question is appropriate, as are the others that said the same thing. The HDMI 1.2 receiver he was considering will not give him advanced audio when connected to a BD30.
post #7265 of 12500
I bought this player on Monday. Can I update the firmware? Is there a firmware on this? If I can update it, how do I do that? Pretty newbie question but I've never thought about updating firmware on anything
post #7266 of 12500
try reading this thread, or better yet, the giant thread about the 1.6 firmware update for the player. later.
post #7267 of 12500
I appreciate all the quick feedback on this topic. I'm in agreement with Macfan's response, as that is what I understood. BTW, I already own the BD30. What I need to figure out is which of the newer crop of receivers, which brand will hook up with the BD30 and give me the TrueHD sound? Is anyone here usingone of the the latest models from Marantz, Pioneer, Yamaha, or Onkyo and able to output TruHD successfully? Thanks!
Originally Posted by mahdlokg View Post
I'm sure this has been covered and I've tried searching searching this thread, but does the DMP-BD30 have the decoder to decode Dolby True HD? I thought I had read where it did not. I'm looking at a receiver that has HDMI 1.2, and need a player with the decoder. Thanks for any assist on this topic.
post #7268 of 12500
Yes you can. The BD30 will deliver LPCM from the analog outputs if the Blu-ray disc has such a lossless audio track.
post #7269 of 12500
The Onkyo 605/705/805 series are HDMI 1.3 compliant and will decode True-HD and DTS-MA coming via bitstream from the BD30. I use a 605 and it works great. I know there are a number of other AVR choices that will work also.
post #7270 of 12500
The Yamaha RX-V1800 and RX-V3800 both do. I have the 3800; works great with both my BD-30 and XA-2.
post #7271 of 12500
Today seems to be my day for semantics. Again, I don't think of PCM as "advanced" because it's been around in one form or another for so long, going back at least to Laserdisc days. But I'll quickly concede that is my personal (mis?)interpretation, and most people would probably consider the 5.1 or 7.1 versions as advanced. And, of course, the BD30 does pass 5.1 PCM through its analog outlets.
post #7272 of 12500
...Is anyone here usingone of the the latest models from Marantz, Pioneer, Yamaha, or Onkyo and able to output TruHD successfully? Thanks!
Pickings are still a little slim, but there is likely to be many more to choose from at a wider range of price points in the next few months. I'm sure most manufacturers will be on the bandwagon soon. I know Sony has announced some low priced versions. Meanwhile, there seems to be a number of happy Onkyo and Yamaha owners here, several of whom have already responded.
post #7273 of 12500
Originally Posted by donaldsonjune View Post
Rynberg,
Not been announced formally but expected to msrp for $600. The real comparison is this:
*single 2.0 compliant player that decodes everything via HDMI and analog at $600
vs
*Yammy receiver, which takes up a lot more shelf space
*interconnects between Yammy and your Rotel
*a big PITA factor in operation of the system
for $500
I know which I would do.
post #7274 of 12500
How so?
Current receivers that decode TrueHD and DTS-HD MA:
*Pioneer Elite 91, 92, and 94 TXH
*Denon 2808, 3808, 4308, and 5308
*Yamaha 661, 663, 1800, and 3800
*Marantz 7002, 8002
*Onkyo 605, 705, 805, 875, and 905
*Sony ES 5300 (and others I think but I couldn't care less about Sony)
Seems like quite a selection to me, price ranges from $400-$5000. There's a few pre-pros out too.
Several models by Sony and Pioneer have been announced for the next months as well, all under $1k.
post #7275 of 12500
Lots of options in AVR land for HBR decoders. Check out the AVRs that support HDMI Audio Multichannel PCM (MPCM) and/or HBR Bitstream Decoders thread.
Less options in Pre/pro land. Check out the thread below.
post #7276 of 12500
post #7277 of 12500
Originally Posted by rynberg View Post
How so?
*Marantz 7002, 8002
Add Yamaha RX-Z11 to the list.
post #7278 of 12500
Yamaha THR6190B = RXV1800 so add that to the list too.
Denon 988 does as well I believe.
post #7279 of 12500
rynberg,
what sound would i get if i go 6-channel out from the bd30 to the 6-channel input to the rotel rsp1068 on bypass mode?????
post #7280 of 12500
Thanks for all the suggestions. That's the info I needed!
How so?
*Marantz 7002, 8002
post #7281 of 12500
How so?...
I was factoring in that most people buy receivers in the <$500 range. (Not in this forum, of course ) There are only a handful of those so far, although more are on the way.
post #7282 of 12500
I don't believe the yamaha 661 decodes the formats. I could be wrong, but I believe that is what the upcoming 663 will do.
post #7283 of 12500
Thanks very much for that reference!
post #7284 of 12500
Ok guys I have the weirdest problem with my player, Last night I was about to watch a movie when I noticed white speckles on the blue Panasonic screen. I'm using a monoprice v1.3 HDMI cable hooked to my Onkyo 805. The weird part is, That ive had my player hooked up for a little over a week now and this just started to happen, could the cable go bad that quick? So what I did was use the HDMI cable from my XA2 and the speckles where worse . I bought these v1.3 cables at the same time just last week, but I see no speckles using my XA2. For my last try to get the speckles to go away was too use a old monoprice HDMI cable that ive had for a few years and bam no more speckles . So how unlucky am I get 2 bad HDMI cables in one week? Oh and by the way the cables are only 3 feet long so distance ant a factor. I think its kind of odd it took a week for this problem to show up, has anyone else had this happen? Thanks again Ryan
here are some pics of my setup:
post #7285 of 12500
^^^^ no help on your issue, but dang i wish i had an HDDVD player that would just bitstream and not internally decode the audio so i could see TrueHD light up when i play the Matrix!!
post #7286 of 12500
Your kidding, right??
post #7287 of 12500
Ok, first an apology for being a newbie. I'v been reading this site for a while. Believe it or not there are a lot of "average' people looking for info to get through the AV maze. Been waiting and waiting and now looks like I only have to think about a Blue Ray player. I understand the Pany BD30 'does not decode TRUEHD'. Simple and practical question: What is the practical downside to this, what will I hear as a difference between true HD, or will I hear any difference? What am I losing , again is there enough of an audible difference, or am I looking at this totally the wrong way. I should get 5.1 and 7.1 through HDMI, correct? I have the Sony 5200 receiver and just got the Mitsubishi 4900 projector. Hopefully won't offend anyone, but for all of us out there who get less and less particular as we get older, do I get the BD30 now or wait for the BD50 (by the way I enjoy watching movies, look at the deleted scenes and bloopers and really don't see a future for me where I need to be on the internet through my blue ray player). Thanks for some practical clarity.
post #7288 of 12500
Never confuse the impossible with the highly unlikely. It could happen. But still, dould you have a strange bend in your HDMI cables that could damage them? Or could you have a physical problem connecting to the pins, like a spot of dirt or grease on your player or receiver? Maybe a slightly loose connection that vibrates with high LFE? Just some thoughts.
post #7289 of 12500
How so?
YOu don't care but others might. Sony STR-DG 2100, can be bought at Amazon or B&H, both authorized dealers, for around $800.
post #7290 of 12500
In your case the only reason I could see to wait for the BD50, would be if you're uncomfortable burning your own update cds. With the BD50, you should be able to update over the internet, with the BD30, you have to burn your own firmware disc.
