Originally Posted by Kram Sacul
They're not blurring, they're disappearing into mush. The effect is very smeary and not like photography at all.
As for The Deer Hunter slight EE is noticable at the top of these frames: http://david2k.orcon.net.nz/hddvd/The%20Deer%20Hunter/AnyC02807.jpg, http://david2k.orcon.net.nz/hddvd/Th.../AnyC02818.jpg. It doesn't ruin the transfer but it's there.
Whatever the cause, it's not an artifact of the transfer/HD compression, which I thought was the point of this thread- to point out compression and/or transfer flaws. This "problem" (which I personally still think looks like normal background blurring due to the camera movement myself) is also evident on the standard-definition DVD release, and also on the Russian PAL DVD which I have. The Russian DVD is notable because it's a completely separate transfer, having been mastered to 16:9 PAL from an actual 35mm anamorphic print (oval cigarette burns at the reel changes and all) as opposed to the DI, and it shows the EXACT SAME "disappearing into mush" of the verticle stripes on the wall as the HD-DVD and region 1 standard-definition DVDs. So clearly, this "error" was evident on the actual 35mm film prints, and thus must have also been present in the original DI used to create said prints and the domestic HD-DVD and DVD versions of the film.
Re: THE DEER HUNTER, sorry but I don't see any "EE" in those screen shots. If there's anything there that resembles "EE", I'm going with captaincelluloid's explanation. I don't think it's a transfer artifact at all.
Vincent
), it had to be done in order to effectively produce the ground breaking digital method for recreating the look of the old Technicolor dye-transfer process.
Specifically, what evils should Dave and Eddie and I be looking for in "The Untouchables" that we are not seeing, and exactly where in the film might we find them?
