AVS › AVS Forum › Audio › Receivers, Amps, and Processors › "Bruised" receiver? What does that mean?
post #1 of 6
Hi,
I just sold an Onkyo 530 receiver to someone, who, after hooking it up to his speakers, noticed it had a lot of noise. He took it to an audio store, and they said it wasn't blown, but it was "bruised."
Just wondering if anyone knew what that meant.
post #2 of 6
I don’t know the technical term, but I would guess it means dropped. Maybe-certain internal hardware like circuits are cracked, loose, or damaged in some way.
post #3 of 6
That could mean anything. It's not a technical term. Could just mean heavily used and on it's way out, it could mean just about anything.
post #4 of 6
Probably means it still works but not to specs, or has some non-fatal problems they may be able to fix.
post #5 of 6
Originally Posted by msnow View Post
Hi,
Did you give any kind of guarantee with the sale? or did you go "as-is" on it?
post #6 of 6
I sold it on craig's list, but I wouldn't want to screw anyone. I heard static out of one speaker when I had it, but thought it was just the speaker.
