When I had tried the V30, I thought Bose told me I could pass through the signal and tv would then up convert it. Agree with you on the short delay, that was annoying.
Originally Posted by ericw530
I was having the same problem you had with my v20. I have the samsung bd-up5000 blu/hd combo player hooked up to my v20 and I was getting nothing but 2 channel pcm. I had to change the audio setting is the samsung player from PCM to bitstream(audiophile) to get true 5.1 surround.
I had called bose, and they said that they v20 is not capable to process the new HD audio formats. That is why the players are defaulted in PCM - for those new HD audio outputs, but if your receiver can't play it it will convert it to a 2 channel PCM (PCM 2.0).
I have been getting great sound with DD 5.1. Wish it could convert the new HD audio formats, but no biggy.
Another grip that I have with the system is that it takes the system about 10 seconds, or so, to receive picture when switching sources or from SD to HD on the cable box. This, from the bose rep, was because of the receiver upconverting the image to 1080p. You can change the settings in the bose system to "fixed" rather than "adjustable" to shorten this delay, but then it won't upconvert every signal to 1080p. If a TV show is 480p/1080i etc then that is how it will be sent to the TV.
