I have narrowed down my search for a remote to the Harmony 720 or 880. My only question is which remote's transport controls are easier to use by feel, in the dark.
IMO the Harmony 670 has the best layout for transport controls. They are conveniently located around the OK button, so you can easily reach all of them with your thumb.
The 670 was designed for DVR use. It is the same shape as the 880, but with better buttons for operating by feel IMO.
My nephew has the 880, but likes my 670 better. But I can't say which one is better between the 880 and 720.
Thanks for the tip. Looks like the 670 is worth serious consideration.
