AVS › AVS Forum › Audio › Speakers › The Official Salk Sound Owner's And Discussion Thread
The Official Salk Sound Owner's And Discussion Thread - Page 153
post #4561 of 8826
Originally Posted by RicardoJoa View Post
Which two ways speakers are you talking about? And when you talk about emphasis on midbass, do you mean a bump in the FR?
Over the years it seems good 3 way speakers sounded better to me than good 2 way speakers (this is very much a generalization). I don't remember specific models from years past, but more recently 2 way models I've listened to are GR Research N2X, GR Research A/V-3, and Usher Mini Dancer 2. I also auditioned the new Magnepan 1.7, and although it is listed as 3 way, all "drivers" share the same diaphram. The 3 way designs I'm comparing them to are the Revel F32 and my own ADS L1290/2. Both of these speakers seem to have less coloration, or slight emphasis, in the lower midrange. To me, the coloration/emphasis I'm refering to makes voices sound like they are singing in a box at times (depending on the notes they hit and the harmonics generated). It can make voices sound a bit muddied at times.
I'm really trying to understand what exactly I am hearing and what causes it (FR variations? Room acoustics? Speaker design?).
Given that even Jim Salk uses a 3 way design in his flagship speakers, there must be some advantage to this. It would be interesting to what is that advantage. One I've heard mentioned years ago was increased power handling.
Originally Posted by R Swerdlow View Post
It might be easy to generalize too much about this. There are both good and bad 2-way and 3-way designs.
The first transmission line (TL) type cabinet I heard were SongTowers. Before that, I thought I could recognize the bass sound from the two basic types of cabinet alignment, sealed and ported reflex. Even if both were properly designed to produce as flat as possible bass response, to my ears the sealed design had a "dry" or "lean" (for lack of better words) sound, and the bass reflex design had a "fat" sound. Of course, these words exaggerate the differences.
When I first heard the SongTowers, I was struck at how the bass sounded unlike any sealed or ported cabinet I'd known. It is a particularly clean sounding bass. Many others have noticed this about TLs, but I'm still not exactly sure what causes it.
All speakers vibrate back and forth producing forward and rearward vibrations. We hear the forward vibrations directly, and in sealed or ported reflex cabinet 2-way speakers, these rearward vibrations can come out through the woofer cones delayed in time from the original signal. This is heard as a muddiness in the upper bass or lower midrange. We hear this even though efforts are made to suppress the rearward vibrations with cabinet stuffing or lining materials.
Dennis Murphy noticed this as well and once pointed out that TL cabinets couple rearward woofer motion to a large column of air that vibrates inside the cabinet. It's carefully constructed so its length is one fourth the cabinet tuning wavelength. Large openings on one end of these cabinets allow this energized air to move freely out of the cabinet. A benefit of coupling the woofer back waves to the air inside the TL cabinet is improved midrange clarity. The front waves from the woofers get little or no interference from internal cabinet reflections as in other designs.
Once I became used to listening to the STs, other bass types never sounded as clean or as good to me again.
My point to this long-winded post is to say, why not put your question about 2-ways vs. 3-way aside until you hear the SongTowers or HT2-TLs?
The more you describe your ADS speakers, the more I'm interested in hearing them.
Thanks for the great information.
I'm certainly not ruling out any 2 way speakers just because they are 2 way. I'm really trying to understand what exactly I am hearing and what is causing it (as I mentioned above in this post).
I really would like to hear a pair of SongTowers and HT2-TLs (especially the HT2-TLs). However, Dennis just mentioned to me in an e-mail that he only got 1 HT2-TL cabinet and I thought he was getting a pair.
I can see from his standpoint (designing crossovers, testing speakers) that he would only need 1 speaker, but I need to hear a stereo pair in order to properly evaluate and compare them to others. So I'm not sure what's going to happen from here (I'm waiting to hear back from Dennis for guidance).
(Warning! Rant to follow.....)
It really sucks that I no longer have a great dealer in my area that carries the speakers I want to audition and would allow me to do so in my home like I use to have some years ago (I dealt with a shop over 20 years before they went out of business). I read how great these speakers sound and want to hear them for myself. As much as others may praise a speaker, it's no substitute to hearing them myself to see if they suit my own preferences.
(OK, I feel better now....)
I guess I will just have to take my time to find were I can audition the speakers on my list. In the meantime, I guess it's not so bad "settling" for my ADSs.
post #4562 of 8826
Originally Posted by Dennis Murphy View Post
Hi There's no reason why a 2-way would have more midbass, lower midrange emphasis compared with a 3-way. The advantage of a 3-way is that you can use a large dedicated woofer that can reach low without having to handle upper frequencies for which it is ill-equipped. It is probably true that relieving the midrange of bass duty cleans up the mids a little, but if the mid did have to operate full range on the bottom, I'm not sure you would hear an emphasis where you think you're hearing one. The mids just wouldn't be as clean. It's more a matter of detail than frequency response irregularities. If anything, there is a greater chance for problems in the upper bass, lower midrange with a 3-way because of the added crossover in that region. If it's not done properly, you can easily end up with either a bump or a dip and noticeable coloration.
Thanks Dennis.
Do you suppose that my speakers may have a dip in this region, and that I'm so use to it that other speakers appear to have an emphasis in comparision?
Perhaps I just need to stop trying to analyze this so much and just go with what sounds good to me.......
post #4563 of 8826
Originally Posted by Saturn94 View Post
Thanks Dennis.
Though it has been years since I listened to ADS, I can say without reservation that things generally have improved since your model was made. ADS had some top quality guys working on them, not the least of which were Michael Kelly (Aerial Acoustics) and Chris Browder (B&W-USA). While they made valued loudspeakers, there is no competition with the drivers, electronics, test equipment, and cabinet machinery available to today's designers.
Likely the differences you heard in some of the speakers you auditioned were due to all of the elements you mentioned, including your familiarity with the ADS. My advice to you is to keep auditioning and then audition some more. (In home auditioning is preferred, natch.)
Will you enjoy the Salks? Only you will know after hearing them. But my guess is 'heck yeah'...or something like that....
post #4564 of 8826
Thanks for the great feedback.
The question I'm trying to answer is not so much if I will enjoy XYZ speaker, but if I will enjoy it more than my current speakers.....enough so that would make it worth spending approx. $3k-$4k.
I'm curious. Have any Salk owners also auditioned any of the other speakers I've heard so far (GR Research N2X, GR Research A/V-3, Magnepan 1.7, Revel F32, and Usher Mini Dancer 2)? If so, how did they compare?
post #4565 of 8826
Thanks Dennis.
Well--there's only one way to find out. Bring them on up. Just for the record--as I already e-mailed you--I do only have one HT2-TL, but I also have a regular HT2. That combo should be enough to tell you whether the HT2's are a step up over the ADS in terms of clarity and sound staging. You won't be able to judge the full bass weight of a pair of TL's, but you wouldn't be far off. And you could compare the bass of the TL and non-TL side by side. Also, I have a state-of-the-art instant comparo preamp, which makes it much easier to A-B speakers without having to rely on memory.
post #4566 of 8826
I read this review of the HT2-TL and hoped to get some feedback from owners.
http://www.audioholics.com/reviews/s...eracity-ht2-tl
Specifically, I hope to get feedback on the following comments from the review.
My impression of the Veracity HT2-TLs is that they need a bit of room to breath.
At best I will have about 3.5ft from the left speaker to the side wall (right speaker would be about 12ft from side wall) and 2ft from the front of the speakers to the wall behind them (this would leave about 7 inches from the back of the speaker to the wall behind). Given the quote above, will I have an issue with placement that will compromise the speakers sound?
I will say, however, that fine tuning was quite a chore. While imaging overall was fine as long as you were close, the nature of ribbon tweeters is that there is a definite sweetspot. If you can hit that sweetspot, you'll get a lot more resolution in your imaging and sound definition. It took a few hours of listening and adjusting before I got it just right. I'd say you should be prepared to do the same.
Are they really that fussy? Is the sweetspot really small?
The one complaint I had with the Veracity HT2-TLs mirrors one I had with the SongTowers - the soundstage width. I'm not sure if this is a function of the design of these two speakers but both of the speakers suffered from a similar limitation. While the Veracitys seemed to have wider soundstage than the Songs, it still didn't seem as wide as it could be and I've definitely experienced speakers with wider soundstages.
This one concerns me as I like a really large/wide soundstage when called for by the recording. Anyone else agree/disagree with the reviewer?
Thanks again to everyone for helping me with my research.
post #4567 of 8826
Thanks Dennis.
I appreciate the assurances and look forward to hearing from you when you are ready for me to come up.
As far as judging the "full bass weight", I'm not as concerned about that as I am with the rest of the frequency band since I will be using a high quality sub (SVS 16-46PC+). That said, the reason I'm looking for a "full range" speaker is so that I will have a bit of flexibility when setting the crossover points for the L&R speakers and the sub.
Speaking of which, currently, my crossover points are a bit unusual. When setting up my sub I had a problem getting the bass "right". It sounded too "hard" for lack of a better term. I ended up measuring the sub, L speaker, and R speaker separately using my Rat Shack meter (and a compensation chart to compensate for the lack of sensitivity in bass frequencies). I discovered that I was getting quite a bump in the 90hz to 100hz range from the R speaker. Since I lacked the flexibility to move the speaker (or my listening position) much at all, the solution was to spread apart the crossover frequencies of the sub and the L&R speakers. I ended up setting the sub at 80hz and the L&R speakers at 160hz. This smoothed out the problem area nicely and brought it in line with the rest of the bass frequencies.
Do you think I'm likely to have the same issue with any speaker?
Thanks again for your help and patience.
BTW, would R Swerdlow also be joining us? I know he expressed interest in hearing the ADSs.
post #4568 of 8826
I have auditioned the Maggie's, Revels and Ushers. The midrange on the SongTower RTs is more clear and detailed than on all three of those speakers. That's just my opinion, so you should definitely audition a pair of Salks if you can. If you're ever near Milwaukee, WI you're welcome to come by and hear mine.
post #4569 of 8826
I definately want to audition the Salks and greatly appreciate the offer. I've also had a couple other offers from owners, but like you they live quite far from here (southeast VA). Maybe I need to offer a free room for any owner who wants a vacation the Williamsburg/Virginia Beach area. All they have to do is bring their Salks with them for me to play with while they're out having fun.
I still may get hear some Salks sometime later this month or so. Dennis has generously offered to let me hear the speakers he has and is interested in hearing/testing my ADSs.
It would have been nice to find a local owner who might perhaps even be willing to bring them to my house so I can check them out in my system, but I've not had any luck finding anyone closer than Dennis (about 3.5hrs-4hrs from here). However, given Dennis's background and expertise, it should be a very interesting and educational visit.
Thank you again for the offer and the feedback.
post #4570 of 8826
Saturn,
Good luck finding someone to bring them to you; that usually doesn't happen and is quite a hassle (I should know - I've done it twice). It's the ideal situation, of course, but not many will be willing to lug their beauties around like that. If you do go to Dennis', though, you'll get the best of everything. It will certainly let you know if you like Salk speakers or not, plus it will be cool to see some measurements of your ADS'.
post #4571 of 8826
Saturn,
Maybe I need to throw in some cash with that room?
Wait a minute, I may need that cash if I upgrade! I may need to rent that room out instead!
Once I get a chance to hear the Salks, then that leaves the Von Schweikert VR-33's on my "want to audition list". I did mention previously about wanting to also hear a pair of VMPS RM30's, but from what I've been reading they seem particulary fussy when it comes to setup/positioning, so I may pass on those (how much better could they be?).
Thank you again for your help and feedback.
post #4572 of 8826
Food for thought: Your comments, and inflexibility with placement are starting to make me wonder if you shouldn't be looking for a stand mounted model instead of a full range floor stander. Your bass hump is likely to occur with any speaker that produces frequencies that low, if placed in the same spot of the room as your current ones. I could be wrong here, but the off center placement and measured hump in room acoustics would push me toward a speaker that didn't even try to be full-range. Forget the bass entirely, let your sub deal with that. Look to the HT1 (and go with a front port), or see if Jim would make you a sealed HT2, or perhaps even a smaller stand-mount version of that speaker if you are hot on the MTM configuration. (Jim has certainly been known to customize his speakers to suit his customers needs... )
On another note... rest assured that midrange clarity is one of the traits that set Salk's apart from everything else. Out of the 30+ speakers that I auditioned during my quest, nothing else had the same clarity, and seamless quality (through the whole range) as the two Salk models that I listened to.
Cheers
-Funk
post #4573 of 8826
I actually considered just that. I just hate to limit myself to needing a sub with the L&R speakers. Yes, for the forseable future, I'm not likely to use the L&R speakers bass capabilities, but since I plan to keep them for a very long time, I don't want to limit myself should my circumstances/audio needs change such that I wish I would have purchased a full range speaker. As an example, my ADSs have served me very well over the past 24 years through several moves, different rooms and setups; sometimes running full range and sometimes with a sub. They've turned out to be a tremendous value. I wish to have the same flexiblity and longevity if I choose to replace them.
It's good to know Jim will customize his speakers to suit the customer's needs. If I decide to go with the HT2-TL, I thought about asking him about my placement issues and if placing the port in the front rather than the rear would help.
Cheers
-Funk
30+ speakers? Wow, I've got alot of catching up to do! Hopefully in a few weeks I can hear the Salks for myself.
I'm thinking I should know this already, but I've been reading so many posts that I sometimes forget who wrote what.......could you remind me of the Salk models that you listened to?
post #4574 of 8826
click the link in my sig and you can see everything that I listened to...
I'm not sure that the TL would allow the port to be placed up front without a complete redesign... which is why I would suggest the non-TL HT2 for you, which (I think) could be modified with a front port. Jim will tell you for sure, I'm just guessing.
post #4575 of 8826
@saturn...
email/call jim and tell him what your room looks like, what your "needs" are and what you might be doing with them in the future, and he'll give you good honest advice about which direction you should go...
when i started conversing with jim, we were hot for a pair of ht-3's... in multiple email discussions with him, he really believed that the ht2-tl's were the better option for us, given our room and usage...
it is RARE that someone who is selling me something recommends spending less money than i intended to originally spend... that alone makes me really trusting of his advice...
ymmv of course... but a data point for you to consider... a lot of people out here are very familiar with jim's products (and a few of them, especially nuance) are what got me in the salk neighborhood to begin with, but imo, the "best" person to ask what will work best is jim himself...
good luck... you'll find what you want...
post #4576 of 8826
…At best I will have about 3.5ft from the left speaker to the side wall (right speaker would be about 12ft from side wall) and 2ft from the front of the speakers to the wall behind them (this would leave about 7 inches from the back of the speaker to the wall behind).
Will I have an issue with placement (of HT2-TLs) that will compromise the speakers sound? In other words, do the HT2-TLs need room to breathe?
Before you consider relocating the rear port of the HT2-TL there are some things you should know about these types of transmission line (TL) speakers such as the SongTower or HT2-TL.
On most speakers, the bass response varies with how close it is to nearby walls. Conventional wisdom has it that the closer a speaker is to these reflecting surfaces, the louder the bass. Depending on the speaker, this can help or hurt the overall sound balance. Many well-designed speakers seem to do better if they are moved further away from walls.
It seems that TL speakers don't suffer from this nearly as much as sealed or bass reflex speakers do. In fact, Dennis Murphy compared his SongTowers placed near (about 8") and far (about 2') away from the wall behind them, and found little difference in the sound. There was definitely no undesirable boomy-sounding bass when they were close to the wall. According to Paul Kittinger, the cabinet designer for the Salk TL speakers, he's observed this same feature in a variety of TL designs he's heard. It may be common to TL speakers in general. In this case, I think the "conventional wisdom" about keeping speakers away from walls doesn't apply (as much) to TL speakers.
Like any very good speaker capable of large dynamic range changes, the HT2-TL will benefit from more "room to breathe" or a large room, but no they do not require it. In fact TL speakers in general (or at least those with Dennis Murphy's characteristic balance and clarity across the midrange) seem to be very flexible about room placement. In my own experience, my SongTowers are the least finicky speakers about room placement that I've known.
So in answer to your question about the distances to nearby walls in your home, I don't think they pose any problem. When you hear the HT2-TL, you should remember to test them in various locations and hear how they do for yourself. You'll also find out first-hand the real reason why Tom Andry (the reviewer of the HT2-TL) complained about moving them. They are very heavy!
post #4577 of 8826
Thanks for the great link. Once I hear some Salks I'll be in a better position to decide if I want to take the next step and discuss specific options with Jim.
Originally Posted by ccotenj View Post
@saturn...
The future part is the big unknown. It has served me well in the past to buy more than I think I need.
That's good to hear. It certainly lets me know he takes customer service seriously.
Thanks for the feedback. Salk owners on this thread have been very helpful. If I'm really impressed with what I hear from Salks (hopefully in a few weeks), then I think I'll give Jim a call to discuss my options on more detail.
That's great to know that the Salk TLs aren't real picky about placement and don't "suffer" when placed closer to the wall behind (I could probably get about 8-10 inches of space behind them). After thinking about it, I think I'm more concerned about what that placement does for imaging and soundstaging more than how much bass is increased. The reason for this is the wide range of crossover options my pre/pro (Anthem AVM 20) offers for the sub and speakers. If bass does prove to be to much, I could always raise the crossover up just enough to tame it. This method proved very effective when setting up my sub with my ADSs.
Hopefully when I meet with Dennis we can try various positions to see how the sound is affected (you can help us move them). We could also see how such various positions affect my ADSs.
post #4578 of 8826
Anyone who is planning to attend the Capital Audio Fest....please, please let us know how things went. I wish you Jim, Dennis and all the guys at Salk the very best of luck for a great Show. This is a fantastic opportunity for people to get that chance to audition Salk Sound...but don't get too busy that I have to wait too long for my STs
GOOD LUCK!!!!!! ;{)
Dennis....I hope you can find time for me to come within the next week...or so.
Rob
Also, I ordered my external Amp yesterday, so I am gearing up for a great system!!!!
post #4579 of 8826
swmbo and i are planning on going on saturday... so i can harass jim in person about getting my speakers done...
of course "planning" and "doing" are two different things, but she's motivated to go, so i think we will make it...
post #4580 of 8826
Hope you guys have a great time... Just disappointed that I can't go!
I'll just be lounging on the beach soaking up some sun. Lord, we just returned from Clearwater, Florida. I gave wifey a choice and that is her final answer!
She is just tired of the clammer of audio quests and of BIGGER/BETTER/FASTER!!!!.
So on to the beach, the sun, the wind, the sand, the salt water, the people....then more speakers!!! Works for me!!! And after all marriage is more than a 50/50 give and take...It it more like 100/100!!! I love my wife!!!
Give and it shall be given!!!!
Rob
post #4581 of 8826
What amp did you purchase?. Forgive me if I have already asked.
post #4582 of 8826
Brandon,
I got the Emotiva XPA-5 and RCA cables too! I am thinking it will be good for me. After I had read the reviews and stayed on the threads, I was convinced of that and it was in my budget.
Rob
post #4583 of 8826
Hey boys, what's going on over here? Looks like good advice still flowing as usual.
Maybe Saturn would be pleasantly surprised with some Song Surround 2's as they are in actuality a fine bookshelf speaker disguised as a lowly surround speaker. You could throw a Songsub in there and have nice system for around $2kish.
post #4584 of 8826
Well I did quite a bit of research and decided that the Song Towers and Song Center were my next speaker. I ordered them last Friday and had a very pleasant talk with Jim in the process. He said they should be ready in about 45 days but I'm in no hurry. I say that now but I'm sure I will be chomping at the bit in about 30 days (maybe 10).
Bill
post #4585 of 8826
PAD,
I agree as this is one of the more friendly threads here on AVS. Your suggestion of the Song Surround II's is a good one as I almost went with the smaller Surround I's. But I knew I would have second guessed my choice so went all in for the Song Towers.
Bill
post #4586 of 8826
Originally Posted by Bill Mac View Post
PAD,
Bill
Hey Bill, why are you giving up the Sierras for Salks and have you auditioned them or ordering by reviews only?
Rob
post #4587 of 8826
Rob
Hey Rob,
I would not say I am giving up on the Sierras just that I got the itch to try something new. I still think the Sierras are excellent speakers and I enjoy them everytime I listen to them. I have not heard the ST's but I have read many excellent reviews. I have also talked with a number of Salk owners whose opinions I respect quite a bit.
Bill
post #4588 of 8826
You are right, great reviews from trustworthy people...what would we do without them! This does help tremendously the decision making progress.
I am very close to my decision to the STs and definitely will know when I take a listen and that is mandatory for this set of speakers. I am not too far from Dennis and hopefully soon I will visit him.
I did hear good things about the Sierra line, I was just curious. I am headed for Richmond one day next week to audition. Some of the dealers here carry a wide range of speakers and it would be nice to have some 'point of reference listening'!!!!
Before I audition the STs, of course. Keep us posted when you get them and your review will be appreciated.
Rob
post #4589 of 8826
Bill
Wow - that's great. Welcome to the club buddy! What veneer?
post #4590 of 8826
Rob
Rob,
Thats great that you can visit Dennis and demo the STs. Also you will get a full education on the STs as well. I look forward to your thoughts on the STs.
Bill
  Back to Forum: Speakers
